speedo cable removal - Ford Truck Enthusiasts Forums
Old 07-07-2010, 12:01 AM
Jordan M Jordan M is offline
Jordan M is new and has a neutral reputation at this point.
im trying to remove my speedometer cable (84 F250), i disconnected it but i cant figure out how to get it through the floor. the hole doesnt seem wide enough
Old 07-07-2010, 12:19 AM
CHELLIE's Avatar
CHELLIE CHELLIE is offline
CHELLIE is gaining momentum as a positive member of FTE.
Quote:
Normally the speedo cable at the speedo head is smaller than at the transmission, you have to remove it from the bottom, if all else fails, make a x cut with some tin snips to the hole, fold the metal out enough to get the cable assy out, replace the cable assy. and tap the metal back into place.
Old 07-07-2010, 02:25 AM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
The cable itself is removed as follows.
Remove the speedometer cable housing from the instrument cluster.
Remove the speedometer cable housing from the transmission or transfere case.
Remove the speedometer drive gear off the end of the cable, it's held on with a "c" clip.
Pull the speedometer cable out of the spedometer cable housing with a pair of needle nosed pliers on the instrument cluster end.
When you reinsert the cable into the housing, use some speedometer lubricant, or white lithium grease. Make sure the cable is well lubricated when replacing it back into the housing.
Old 07-07-2010, 08:45 AM
eqppwqqep's Avatar
eqppwqqep eqppwqqep is offline
eqppwqqep is starting off with a positive reputation.
Not to threadjack, but if you don't grease it properly will it twitch and jump around?
Old 07-07-2010, 08:53 AM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
Quote:
Yes it can.
Also, if you are trying to replace the entire cable and housing, you need to either take the top thru the firewall, or at least remove the trans/transfer case adapter from the lower end. Pulling the rubber grommet out of the firewall *should* allow the upper end to fit thru the hole.
Old 07-07-2010, 10:55 AM
eqppwqqep's Avatar
Quote:
Originally Posted by Rogue_Wulff View Post
Yes it can.
I was messing with mine this weekend and I was able to disconnect the cable from the gauge without removing the cluster. Then, as you said, the rubber grommet in the firewall can be popped out and the whole cable assembly can be pulled toward the engine and out of the cab. On mine, there is plenty of room for it to fit. Then it's just unbolting it from the tranny.
2003 Escape Shifter Cable Adjuster Expedang Escape & Escape Hybrid 1 11-10-2014 08:46 AM
Parking brake cable removial Necco-2 1961 - 1966 F-100 & Larger F-Series Trucks 14 07-02-2012 03:38 AM
Replacing Parking Brake Cable KillerTux 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 08-13-2011 11:01 PM
Odometer cable replacement on F250 Ric Simons 1987 - 1996 F150 & Larger F-Series Trucks 1 12-22-2008 12:27 PM
Speedo cable removal from speedo grey77 1973 - 1979 F-100 & Larger F-Series Trucks 5 03-21-2005 08:24 AM
Tags
1972, 2008, 84, bronco, cable, f150, f250, firewall, ford, grommet, housing, ii, remove, speedocable, speedometer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
