How to replace multi function switch
REMOVAL:
* 1. Disconnect the battery ground cable.
* 2. Remove the ignition switch lock cylinder.
(1) Insert the ignition key into the ignition switch lock cylinder and turn to the RUN position.
(2) Push the (A) ignition switch lock cylinder release tab with a punch while pulling out the (B) ignition switch lock cylinder.
* 3. If equipped, twist the tilt wheel handle and shank and remove.
* 4. Release the (A) four clips and remove the (B) steering column opening cover.
* 5. Remove the upper and lower steering column shrouds.
(1) Remove the three screws.
(2) Remove the lower steering column shroud.
(3) Remove the upper steering column shroud.
* 6. Remove the multi-function switch.
(1) Remove the two screws.
(2) Disconnect the electrical connectors.
(3) Remove the multi-function switch.
PStruwing
15
11-09-2015 06:17 PM
