97 f150 speedometer which fuse?
Old 06-30-2010, 03:16 PM
lestro's Avatar
lestro
lestro is offline
Question 97 f150 speedometer which fuse?
bought a 97 f150 4x2 with the 4.2 automatic. anyway the speedometer doesnt work. I'm assuming it electronic, which fuse would it be? I didn't see it on the list. thanks in advance
Old 07-06-2010, 10:00 PM
kabcpapc's Avatar
kabcpapc
kabcpapc is offline
I have a 1997 F150 with the 4.6L V8. The speedometer/odometer appears to be the old style, not electronic. If yours is the same, then no fuse. You may have a broken cable or teeth missing on the cog.
Old 07-07-2010, 01:54 PM
lestro's Avatar
lestro
lestro is offline
mine looks like the old style also, but I crawled under it and there's no speedometer cable going to the transmission, just a connector with a wire towards the rear of the transmission. regards
67aj
12-24-2016 07:34 PM
67aj
Electrical Systems/Wiring
12-21-2016 06:01 AM
TruckLover97
New Member Introductions
05-18-2016 12:07 PM
Sancho
1997 - 2003 F150
10-31-2015 05:30 PM
juanjayala7
1997 - 2003 F150
06-04-2010 01:22 AM
Quick Reply: 97 f150 speedometer which fuse?
