Starting Issue
Starting Issue
2001 Supercrew 4.6 2wd. Isn't a problem yet but would like to fix it before it becomes one. When I go to start it after it sits for a while(ie over night, after I get off work) it cranks over for a while before it starts. Longer than it should. When I get in it after running an errand, something quick it fires right up
I am unsure how these trucks keep the fuel in the lines, someone else will have to chime in on that. But at least I can help you figure out if that is the problem.
dpoc
18
09-25-2011 08:39 PM
jeffsonday
01-28-2011 01:44 AM
