1976 - 1996 F250 Truck Ball Joint LOWER PAIR (MOOG K8195T) for 4WD Models
<a href="http://www.1aauto.com">
<img src="http://www2.1aauto.com/_include/gui/logo_large.gif" alt="1A Auto Parts" title="1A Auto Parts" border=0>
</a>
Click here for pricing
MOOG K8195T [FRONT LOWER BALL JOINT] PAIR
This Moog brand replacement Lower ball joint PAIR is just what you need to insure the safety and integrity of your vehicle's suspension and steering.
Specifications:
Comes as a PAIR
Fits both the LH (Driver) & RH (Passenger side) FRONT LOWER
Fits into knuckles or Lower control arms depending on application
Direct replacements
Built to strict quality control standards
Correct for 4WD models only
Worn ball joints can cause excessive front tire wear, popping or creaking in the front end, extra play in the steering system, and pose a serious safety concern. Replace loose or worn ball joints with our quality replacement.
One way to diagnose a loose, or warn ball joint, is to jack the car up, so the wheel is off of the ground, then have someone try to move the wheel in and out. While they are moving the wheel check the ball joint for play, if it is moving you probably need to replace it.
</a>
Specifications:
Comes as a PAIR
Direct replacements
1Aauto
Vendor Specials, Discounts, Product Announcements & Group Buys
06-16-2016 12:24 PM
1Aauto
11-22-2013 01:56 PM
1997-1999 Ford F150 Truck 4WD Front Wheel Bearing & Hub Assembly for Models with Rear Wheel ABS Pair
1Aauto
05-21-2013 10:38 AM
1Aauto
05-21-2013 10:33 AM
