Truck shakes when accelerating - Ford Truck Enthusiasts Forums
Old 07-05-2010, 09:20 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD BURNSTOUGHFORD is offline
BURNSTOUGHFORD has a good reputation on FTE.BURNSTOUGHFORD has a good reputation on FTE.
Its not the tires/wheels. Ijust had them balanced.
It only shakes when hard accelerating. If im easy on it, then smooth as can be.
It gets worse with the RPM of the engine. Im thinking its in the tranny.
It still shifts smooth and i have been pulling 17 mpg on the interstate with it. So i know its acting correctly?
Could i have blown something in the trans or balloned the torque converter?
It just started the other day, i drove about 350 miles on vacation and noticed it when i went to come home.
Like i said it only shakes when you lay in to the throttle, and it gets kinda violent.
Old 07-05-2010, 09:24 PM
firefighter1416's Avatar
firefighter1416 firefighter1416 is offline
firefighter1416 is starting off with a positive reputation.
Not sure if these trucks have them but harmonic balancer?
Old 07-05-2010, 09:35 PM
SteevenH SteevenH is offline
SteevenH is starting off with a positive reputation.
Sounds like U-Joints but could also be clutch's in the rearend. Clutch's would really be noticeable when turning left and accelerating and when you first take off. Unless U-Joints are really bad they're not as noticeable on easy takeoffs, moreso on hard.
Old 07-05-2010, 09:41 PM
nope this is straight line getting on the interstate type shaking.
Old 07-05-2010, 10:29 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
"Like i said it only shakes when you lay in to the throttle, and it gets kinda violent. "
related to engine power, not motor speed or ground speed... sounds like a COP failure ? no code?
Old 07-06-2010, 07:39 AM
It seems to be based on load on the truck. Only when i get on it hard does it do it.
The truck does not have COP's. It is a coil pack ignition system. Plugs are less than 30k.
Old 07-06-2010, 09:42 AM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.
My bet is that it's ignition related.
JL
Old 07-06-2010, 09:03 PM
I think its my u joints. both the rears had some play. wont know for 3 weeks untill i get back home to replace them
Old 07-08-2010, 12:48 AM
kAriyaKicHickEn's Avatar
kAriyaKicHickEn kAriyaKicHickEn is offline
kAriyaKicHickEn is starting off with a positive reputation.
I have an 03 F150 and I started having similar problems a while back. For a few months, I noticed my truck would kind of "jump" when I was accelerating, but it only did it every once in a while. A few days ago though, I was on the highway trying to speed up and around 50 mph it started shaking pretty bad. I let off, tried to speed up again, and it shook again. So I let someone else drive it and they think it's transmission problems. It didn't shake as bad, but they said it's slipping in 3rd gear. I'm probably going to take it in tomorrow
Old 07-08-2010, 03:28 AM
ATC Crazy's Avatar
ATC Crazy ATC Crazy is offline
ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.
Sounds like torque converter shudder to me. These trucks were notorious for it.
Old 07-08-2010, 06:23 AM
thefordguy thefordguy is offline
thefordguy is starting off with a positive reputation.
Quote:
I had to look that up and now I know what that feeling was when I was a kid. A delivery place I worked had a Dodge Dakota that would shake at highway speeds, especially between 3rd and 4th gear. I bet it was the TC.
Torque Converter Shudder Problems | eHow.com
Old 07-08-2010, 05:59 PM
Mine shakes in every gear. But only when im accelerating or decelerating (when locked in a gear). When going constant, its pretty much smooth.
Old 07-09-2010, 04:01 AM
ATC Crazy's Avatar
Does it do it while taking off from a stop under steady acceleration in a straight line? I say straight line to eliminate the chance of shudder from the LS unit...
Old 07-09-2010, 05:30 AM
Darshana72 Darshana72 is offline
Darshana72 is starting off with a positive reputation.
Quote:
Thank you for the suggestion. I also use this idea for my truck and it works. thanks again for your post.
Old 07-09-2010, 10:18 PM
Nothing to do with the LS.
I have determined that it is the engine missing now. Its very weird. I have been around these motors/trannys for 10 years now. I know my way around for the most part.
Haven t had these issues yet without a CEL. Im thinking its gotta be a plug/plugwire/ or coil pack. Well just see. Like i said, theres now CEL. no codes.
Truck shakes at highway speeds Jakeadams910 6.0L Power Stroke Diesel 6 03-06-2017 08:19 PM
Something strange Freddie3026 1987 - 1996 F150 & Larger F-Series Trucks 0 12-19-2016 09:07 PM
highway speed hop eberlestock 1999 to 2016 Super Duty 1 09-05-2016 11:48 AM
1996 Ranger Shaking Under Acceleration Aerobane Ranger & B-Series 3 09-16-2012 11:09 PM
03 F250 Acceleration Problem hogwaller 1999 to 2016 Super Duty 3 11-09-2009 05:57 PM
Tags
150, 75, 99, accelerating, bad, f150, f250, ford, forum, shake, shakes, shaking, shudders, taking, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
