Power Steering Pump pressure (again) - Ford Truck Enthusiasts Forums
Old 07-05-2010, 08:32 PM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
Well, after the saga pf the squealing pulleys, you'd think I would be done.. but NOOOO.. this steering is just not right.... and the red 56 has a volare and a remote reservoir pump which works perfectly (actually jumpy in comparison to the green truck)
SO... attack plan..
1. buy a hi pressure guage set ($100) and measure the PS pressure of the mercedes pump... (weak info from a dealer implies 1000psi.. enough)
1a if pressure low, figure out what to do, replace pump...
1b if pressure ok, then try another steering box (second rebuilt on installed already)... maybe a red-head box
2.. replace steering pump with GM style pump
like either of these .. small reservoir, or large reservoir..
maybe replace gear again
Anyone used the small reservoir pump?
Sam
Old 07-05-2010, 09:03 PM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
Maybe? some info:
Plews Edelmann
I've been searching for the past 6-7 yrs for a "Spec" list - even spent several days at the library looking a repair manuals - no joy.
Old 07-05-2010, 09:19 PM
sdetweil's Avatar
cool info, thanks..
I would classify this as loose/wander
<table width="100%" border="2" bordercolor="#000000" cellpadding="2" cellspacing="2"><tbody><tr><td valign="top">Vehicle wandering from side to side </td><td valign="top">Front end misaligned </td><td valign="top">Check and align to specifications </td></tr><tr><td valign="top">
</td><td valign="top">Worn front end parts or wheel bearings </td><td valign="top">Inspect and replace affected parts </td></tr><tr><td valign="top">
</td><td valign="top">Unbalanced or badly worn steering gear control valve </td><td valign="top">Inspect and replace affected parts </td></tr></tbody></table>
everything has been replaced.
rubber bushings, ball joints, tire rod ends, idler arm,
pitman arm, steering gear (twice).. hoses,
only thing NOT changed is the steering pump. and it WAS used when I bought it.. 5 yrs ago now I think.. maybe 6.
AND its a weird duck compared to all the other experiments here: Ford, Chrysler, GM
I popped the tie rod ends before Smoky Mountain, and the spindles pivot on the ball joints just fine..
Sam
Old 07-06-2010, 07:31 AM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
Sam,
Way back many a moon ago, back when they overhauled parts at the dealer instead of just replacing everything we used to overhaul power steering pumps. I don't recall the pressures but I do know the the pressure regulators in the pumps were adjustable. I worked on GM stuff which used saginaw pumps. The pressure regulator screw into the back of the pump and is the fitting for the pressure hose. From what I remember you adjusted the pressure by shimming the regulator depth into the pump body.
Bobby
Old 07-06-2010, 07:44 AM
56panelford's Avatar
56panelford 56panelford is offline
Posting Legend
56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation
Quote:
Originally Posted by 4tl8ford View Post
Maybe? some info:
Plews Edelmann
You're one studious dude Dick
Old 07-06-2010, 08:00 AM
sdetweil's Avatar
Quote:
Originally Posted by bobbytnm View Post
Sam,
Bobby
if only I HAD a gm pump..
Sam
Old 07-06-2010, 08:31 AM
4tl8ford's Avatar
Quote:
Not really - I use the concentration needed for research to fight the nerve and muscle pain that I live with.
Old 07-06-2010, 11:11 AM
HT32BSX115's Avatar
HT32BSX115 HT32BSX115 is offline
HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.
Howdy,
I don't where you're going to buy that high dollar gage set but you can go to the Surplus Center and buy the gage below (and just about all the other gages they have for under $20!
This one is $12 + shipping!
And if that's not enough pressure or too expensive, you can get the following one for a whopping $7.99!
This one is my favorite at $2.95 (I'm cheep according to my wife!!!)
2000psi at full scale
Old 07-06-2010, 11:22 AM
fergusonicford's Avatar
fergusonicford fergusonicford is offline
fergusonicford is starting off with a positive reputation.
Sam, I'll bring my GM pump (as pictured on the right) to the carshow Saturday in McDade for you to experiment with if ya want. I just have to find it tonight.
Brad
Old 07-06-2010, 12:08 PM
sdetweil's Avatar
Quote:
Originally Posted by HT32BSX115 View Post
Howdy,
yeh, and hoses, and adapters, and ...
S & G Tool Aid 34650 Tester - Hydraulics
sam
Old 07-06-2010, 12:09 PM
sdetweil's Avatar
Quote:
Brad
is it press on or keyway (bolt on) pulley?
Sam
Old 07-06-2010, 12:25 PM
keyway. I have some hoses for it also.
Old 07-06-2010, 12:38 PM
sdetweil's Avatar
I have hoses (same connections).. got to find a serpentine pulley
Sam
Old 07-06-2010, 10:28 PM
bobbytnm's Avatar
Sam,
You might try searching around some of the sites catering to circle track racing (dirt pavement, etc). Those guys might now how to modify your pump or where to get parts for it. I'm betting the pumps are all the same basic design; a rotor vane pump with some sot of pressure regulator consisting of a spring and disc that restricts the flow.
Good luck with it
Bobby
ps. I always learn tons from your tinkering
Old 07-06-2010, 10:59 PM
sdetweil's Avatar
yeh, tinkering.. if thats what u call it.. troubles is more like it..
course I continue to use part A and V together.. regardless of where they come from!..
Sam
power steering - leaking line pdqtimetrialer 2004 - 2008 F150 9 08-07-2016 09:28 PM
How To: Power Steering Pump Replacement nstueve 1987 - 1996 F150 & Larger F-Series Trucks 80 02-05-2016 12:33 AM
Power Steering Fluid Flush coolfeet 1968-2013 Full Size Vans 5 09-24-2014 12:34 PM
How do i flush my Power Steering? Restlesswildman 6.0L Power Stroke Diesel 32 02-03-2014 01:18 PM
Replacing Power Steering Fluid Reservoir little dutch 1987 - 1996 F150 & Larger F-Series Trucks 8 01-23-2010 06:44 PM
Tags
1955, 1997, 2010, 460, 73, f150, f350, ford, power, pressure, pump, regulator, replace, saginaw, steering, weak
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
