E350 460 eng battery size/cranking issue - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 07-05-2010, 03:09 PM
mainiac1 mainiac1 is offline
mainiac1 is starting off with a positive reputation.
Hey there,
I have an 85 E350 RV with a 460 engine. Just replaced the battery (Still under warrentee; Napa tested old batt and it was bad,) 2 months ago because it barely cranks the 1st time you turn the key...like the timing is way advanced. But every time there after, it cranks fine. I mean it has a hard time getting the engine to turn over the 1st few revolutions, but turns it and starts it ok every time after the innitial crank. it has a 820 amp Napa battery. I pulled the battery and altinator and had them both checked at Advance Auto, both check good. I pulled the battery terminals, starter relay terminals and pos wire going to starter and wire brushed them including the main ground wire going to the engine block. Surely 820 amps is plenty for this engine, no?
Wire gage I'm not sure of...is close to 1/4" dia so should be a 1 or 2 gage, but not sure if thats large enough. Looks like its been that way for a while though.
Chiltons doesn't show wire size in the book I've got either.
any ideas on this solving problem?
Thanks, Jamie
Old 07-05-2010, 11:13 PM
maples01's Avatar
maples01 maples01 is offline
maples01 has a good reputation on FTE.maples01 has a good reputation on FTE.maples01 has a good reputation on FTE.
Sounds like the timing to me, how many miles are on it.
Old 07-06-2010, 10:34 AM
98k on it. Guess I'll have to get the timing light out and check it.
Thanks, Jamie
Old 07-13-2010, 01:28 PM
spikedog's Avatar
spikedog spikedog is offline
spikedog is gaining momentum as a positive member of FTE.
Shooting in the dark here, but did you change the right battery? There should be a starting battery and a service battery (deep cycle) to run the lights and furnace in the RV living area. The starting battery is on the passenger side.
820 CCA seems like a awfully big battery - I've only got a little wallyworld battery on my 1982 RV that cranks out 550 CCA. The deep cycle battery is in front of the driver.
Old 07-13-2010, 04:01 PM
Yeah, I know which battery is which. My next step is to check the timing, then pull the starter and have it checked at autozone. Could be drawing too much current.
Thanks, Jamie
88 Ford F350 with electrical issues andyofne 1987 - 1996 F150 & Larger F-Series Trucks 24 10-09-2016 03:58 PM
Voltage Drop Testing How-To: Fix That Slow Starter kr98664 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 06-20-2016 10:17 PM
Alternator Wiring Issues, Blown Fuse? Bubba Hines 1973 - 1979 F-100 & Larger F-Series Trucks 3 12-19-2015 10:06 PM
1990 Ford 460 ignition/alt problems. Urban Monkey 1987 - 1996 F150 & Larger F-Series Trucks 5 10-08-2015 01:17 AM
turning over real slow... North42g 1966 - 1977 Early Broncos 95 08-02-2011 09:12 AM
Tags
1978, 2008, 460, amps, battery, cold, cranking, e350, engine, f150, ford, motor, required, size, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
