1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
F250 idles fine, pressing gas gets no response
Old 07-05-2010, 11:06 AM
cobradcab6's Avatar
cobradcab6
cobradcab6 is offline
I've got a 2000 F250 diesel 2 wheel drive. Was driving fine until all of a sudden turned the truck on and the engine started fine, and idles fine, but when I press the gas pedal, nothing happens. It will idle forward in drive, and idle backward in reverse. When I put it in drive, it seems to engage fine, I just get no response when I press the gas. Any ideas what this could be?
Old 07-05-2010, 03:28 PM
mcantar18c's Avatar
mcantar18c
mcantar18c is offline
How's the trans fluid look?
When was the last time it was changed?
Old 07-05-2010, 06:49 PM
F350-6's Avatar
F350-6
F350-6 is offline
Welcome to FTE. Your accelerator pedal is electronic. Sounds like the sensor on the pedal is acting up or has gone out on you. First off, check all your fuses with a test light to make sure it's not something that simple.
It seems like the 2000 model had a IVS (idle validation switch) that could be replaced without replacing the entire pedal assembly. Finding someone with a good scanner that can monitor live data will tell you for sure.
Old 09-01-2011, 09:57 PM
F250MAMOU's Avatar
F250MAMOU
F250MAMOU is offline
2007 f250 diesel no response from fuel pedal; idles but no response from pedal!
2007 w/ 91,000 miles FX4 4x4 Super Crew Diesel.
Will run fine for a couple of days just fine and then will randomly decide to not respond when I press the pedal. Nothing. Nadda. No rpm response, but will idle. Will occasionally idle then slowly decrease rpms until it dies out. Eventually it will respond. If I mash the pedal...nothing. Pump the pedal...nothing. RPM's at 1000 or less. Then all of a sudden VROMMMMM it responds and is good as new.
I brought it to the dealer and after 3 days they say it is throwing no codes. they say they will have to put some miles on it and replicate the problem. I am at wits end!!
Can anyone help?
Thanks,
Paul
Old 09-02-2011, 02:04 AM
mountie's Avatar
mountie
mountie is offline
Same exact problem with my 02. The dealer replaced the pedal sensor and solved the problem.
Old 09-02-2011, 02:29 AM
carltonwebb's Avatar
carltonwebb
carltonwebb is offline
To the OP, Check fuse 19 inside the cab. Should be 10 amp. Part of your instrument cluster and the overhead console if u have should be dead as well if it is blown.
If it is blown, it was probably caused by the OD cancel switch wire rubbing inside the steering column. There are couple of writeups on what to check if that is the case.
Old 09-02-2011, 05:29 AM
F250MAMOU's Avatar
F250MAMOU
Thanks for the info. My dealer is driving me nuts! I pulled in while I was experiencing the problem and tried to get him to check it out then and there. He said they would check it out. what happened is that they let it sit there and when they tried to start it they had no problems. How did they figue out that it was the pedal sensor?
Old 09-02-2011, 04:07 PM
carltonwebb
Yours is different. I know that but not sure of the specifics for the 07 6.0. My response was to the Original poster with the 7.3.
Come down to the 6.0 forum and post your question as its own topic. There are guys in there that will be able to answer it for you.
Old 09-03-2011, 01:16 AM
mountie's Avatar
mountie
mountie is offline
I don't know. When I told him on the phone, his reply was it's sounds like a pedal sensor. I dropped the truck off and an hour later he called and said truck's ready. It was the pedal sensor. I don't know how they check it.
Old 09-03-2011, 12:13 PM
F250MAMOU's Avatar
F250MAMOU
I need a new dealer. My experience was very rushed and unpersonal.
Old 09-03-2011, 01:43 PM
BigPigDaddy's Avatar
BigPigDaddy
BigPigDaddy is offline
Paul,
You certainly do need a new dealer, or a reputable shop that isn't a dealer. It is ridiculous that they only look for codes. Seriously, they have it for 3 days and probably never even put it in a service bay. After ignoring it for 2 days they probably went out to where it was parked, hooked up the code reader, found no codes and called you to tell you that they need to drive it to replicate the problem. I've seen this at other Ford dealers over the years and it is just poor customer service because they figure they have you by the b@lls and you won't go anywhere else. You need to find a shop that doesn't rely on code readers.
Old 01-31-2016, 04:01 PM
Kadin Cook's Avatar
Kadin Cook
Kadin Cook is offline
Can anyone help?
Thanks,
Paul
I know this was 4 years ago but my 01 f150 is doing the same exact thing, did you figure out the issue?
Old 11-13-2022, 09:16 AM
Friday Fritz's Avatar
Friday Fritz
Friday Fritz is offline
1st Gear
no response to throttle
My f350 2009 ford sometimes has no response to the throttle when i'm driving. it will just idle. after awhile it works fine again.
Huntot7
08-02-2017 07:58 PM
jrgrtx
07-26-2017 05:06 PM
b.hope014
1997 - 2003 F150
05-04-2017 01:02 PM
Jtrainer16
08-21-2016 10:59 AM
Alfredoquiroz
02-18-2016 12:03 AM
Quick Reply: F250 idles fine, pressing gas gets no response
