OPERATION BETTER MPG!!
All my friends have newer trucks and give me a hard time for driving this old girl. She runs good and is paid for but gets awful gas mileage. My friends have newer gm trucks that get 14-16 in town. Im gonna try my best to get her there.
fueleconomy.gov
says the rating on my truck is
city-12
highway-17
combined-14
newer chevy 4.8/5.3
city-14/15
highway-19/20
combined-16/17
newer ford 4.6/5.4
city-14/13
highway-19/17
combined-16/14
newer dodge 4.7/5.9
city-13/13
highway-18/19
combined-15/15
Ok boys I got a 1995 F150 5.0L auto 2wd extended cab,3.31 gears,225/75r15 tires and is bone stock! The truck has 217k on it and the motor was rebuild 75k ago. So Im gonna do a few things in hopes to bring it up. My daily driving is 16 miles round trip. Its a mix of light traffic,lights and straight aways. I dont lead foot the truck but I dont putt either.
Stock: avg 10.7mpg {3 tanks of gas}
Removed stock muffler: avg 12.1mpg {3 tanks of gas}
*still have both cats. My exhaust currently ends at the back of the cab. Yes Im gonna change it.
Future plans:
tune up
gut the cats with a turbo muffler
delete egr
remove all the smog
Im open to suggestions!
Saturday morning I replaced the radiator because mine had a leak. I have a buddy that works for jaguar that hooked me up with a electric fan setup from a car they warranted the radiator assembly. Its a trick setup. I was reading on the f150 forum some guy did it to his 5.4L triton and went from 11-12mpg up to 13-14mpg. We will see. I know people say its like 15-20hp. Truthfully I didnt notice anything as far as power difference. I will keep you updated.
Is some pics of the fan setup. Sorry about the wiring I have not cleaned it up yet. It was a pain in the *** let me tell ya. I bought a fan control setup that was for 2 fans with ac. Had a 45 amp relay and 20 amp fuse. I wired everything up and it worked great for about 20 minutes. One fan was on with the ac and the other was coming on at 160 degrees. I took the truck to get food and noticed the sc was not blowing cold. I popped the hood and the 20 fuse was melted. I thought for 2 fans a 20 amp and single relay was not enough but it thats what it showed to be setup for. I added a extra relay and ran the wire from th controller to the 12v turn key side of the 2nd relay. Added a 30amp fuse for both relays. Well the relay that ran the motor fan {thermo controlled but temp was fine} but the ac fan kept blowing fuses. So I cut the wire from the controller for the ac. I hooked it up straight from the ac. No change it kept popping fuses. So I cut that wire and just hooked it up to the turn key 12v power source. Problem solved!! One fan comes on when the key is on while the other comes on a 160 degrees. Here are the pictures of the setup. I will clean up the wiring I just ran out of time.
cell phone pics! sorry
I will update this post with the new mpg good or bad
some mpg threads
https://www.ford-trucks.com/forums/9...rs-are-in.html
fueleconomy.gov
city-12
highway-17
combined-14
newer chevy 4.8/5.3
city-14/15
highway-19/20
combined-16/17
newer ford 4.6/5.4
city-14/13
highway-19/17
combined-16/14
newer dodge 4.7/5.9
city-13/13
highway-18/19
combined-15/15
Future plans:
tune up
delete egr
remove all the smog
some mpg threads
i used Thermostatic Fan Control - Preset by Imperial - Part 226206 - Advance Auto Parts if the link doesnt work its imperial e-fan relay preset to 185
my fan setup almost covers the entire radiator too...
i did notice the engine picked up a little faster of course my fan clutch was shot lol ;P
what gear ratio do u have
ok so u know the sticker on the drivers door jam has a thing around the bottom that says axle and see mine says 18 which is a 3.08
and then Ford Door Sticker Decoder .: Articles to decode it
Mine says 17
didnt see it on thar list.
On another thread I saw this
Axle Decoder Chart
Code Ratio Capacity Maker Type Yr
12 2.73 3800 FORD REG 1991
17 3.25 3300 FORD REG 1971
17 3.31 3800 FORD REG 1995
18 3.08 3800 FORD REG 1991
19 3.55 3800 FORD REG 1991
25 4.10. 5300 FORD REG 1991
29 3.55 5300 FORD REG 1991
35 4.10. 6250 FORD REG 1991
36 3.73 7400 DANA REG 1980
39 3.55 6250 FORD REG 1991
45 4.10. 7400 FORD REG 1991
49 3.55 7400 FORD REG 1991
65 4.10. 8250 FORD REG 1991
69 3.55 8250 FORD REG 1991
72 4.63 11000 DANA REG 1991
73 5.13 11000 DANA REG 1991
H5 4.10. 3800 FORD LIMITED SLIP 1991
H7 3.31 3800 FORD LIMITED SLIP 1995
H8 3.08 3800 FORD LIMITED SLIP 1991
H9 3.55 3800 FORD LIMITED SLIP 1991
B5 4.10. 5300 FORD LIMITED SLIP 1991
B9 3.55 5300 FORD LIMITED SLIP 1991
C5 4.10. 6250 FORD LIMITED SLIP 1991
C9 3.55 6250 FORD LIMITED SLIP 1987
D5 4.10. 7400 FORD LIMITED SLIP 1991
F5 4.10. 8250 FORD LIMITED SLIP 1991
W5 4.10 8250 FORD LIMITED SLIP 1995
Axle Decoder Chart
on
All good except the EGR.. that actually helps fuel milage so you're better to leave it alone. You can however delete the thermactor(air injection) system, that's all the plumbing and valves connected between the air pump and the back of the motor, and the tube that runs down to the cat is also part of it. To prevent codes simply leave the TAB and TAD solenoids beside the coil electrically connected but remove or cap the vacuum lines.
Further mods that will help engine power and milage are shorty headers, 1.7 rockers, and advancing the timing, stock it's set at 10deg and some motors will tolerate 2-4deg more.
With the 1.7 rockers with the stock springs be ok>
Random Q, but how much HP does the power steering consume on the highway? I figured that these trucks do about 100,000 BTU of work in an hour going 60 mph. The alternator draws ~ 1 hp, which goes to 2500 btu/hour. So total alternator delete should give 2.5% fuel mileage increase (probably not worth it)
Say the P/S is a 3 HP, if that could be cut down to half on the highway, gains might be 1/2 a mpg.
Also, removing the 3" body lift from my truck seems to have earned me an extra mpg.
Paul, if I removed the thermactor, could I put an old style alternator bracket (where you move the alternator, instead of a spring tensioner) on the truck?
