Steering pulls hard one way then the other. - Ford Truck Enthusiasts Forums
Old 07-05-2010, 10:25 AM
trike1946's Avatar
trike1946 trike1946 is offline
trike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud of
Hi, I have an 01 F250, 4x4. All ball joints and ends are new. Everything is tight underneath. Sometimes when I make a 90 degree turn, when it straightens out it goes hard the other way, pulling into the next lane. Sometimes it just starts to pull while going straight. I am thinking maybe the booster????? Is this a possibility or is the steering box more likely? It doesn't always do it so I don't think it is mechanical, more hydraulic. Tires are good and alignment is also good.
Thanks for any help.
Old 07-05-2010, 12:04 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
Sounds like an axle shaft U joint might be froze up. Turn the wheels all the way in either direction, reach into the U joint and turn the shaft to see if there is any resistance / binding.
Old 07-05-2010, 06:46 PM
trike1946's Avatar
Thanks for the reply. I had to do some work today and just got home. I will try it first thing in the morning. Never thought of that problem.
Old 07-07-2010, 12:09 PM
trike1946's Avatar
Well I checked both sides and nothing seems wrong. I have had it to the front end shop and they couldn't find anything either. Can it be the valves that switch the steering pressure from one side to the other? I even switched tires to see if it would help, but no change.
2011 F250 - braking issue Zejokee 1999 to 2016 Super Duty 10 09-23-2016 09:38 PM
Power steering flush needed? 20powerstroke02 1999 - 2003 7.3L Power Stroke Diesel 11 10-02-2015 10:57 AM
Specific steering question Watcher58 Excursion - King of SUVs 2 01-18-2015 05:53 PM
2005 F250 4x4 steering,, HELP! Butch(OH) Brakes, Steering, Suspension, Tires, & Wheels 7 07-07-2013 12:13 AM
Power Steering jerks to left or right ch435 Brakes, Steering, Suspension, Tires, & Wheels 4 06-11-2011 06:32 PM
Tags
direction, f150, f250, f350, ford, frozen, hard, joint, pulling, pulls, side, sides, steering, steers, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
