1996 F super duty- O.D. wiring diagram
Old 07-04-2010, 04:38 PM
Az.Nick's Avatar
Az.Nick
Az.Nick is offline
Hello there,
Have a 1996 F super-duty that I need a wiring diagram for the "overdrive switch" on the shifter. Don't know which wire goes to which, any thoughts/leads would be appriciated.
Nick
Old 07-05-2010, 03:49 PM
Hussler's Avatar
Hussler
Hussler is offline
Originally Posted by Az.Nick
Hello there,
Nick
Hi Nick, welcome to FTE. Sorry no one has responded yet but with the big weekend and all .. ya know. I did lots of honey - dos' but did get a chance to detail the truck out a bit.
Anyway you can use this online service manual link and it should answer your question.
1996 Bronco/F-Series Workshop Manual
Click on -> Transmission -> Automatic External Controls -> Electrical Schematics and scroll down a bit. Post back and let us know if you got it fixed or need additional help
Old 07-05-2010, 06:23 PM
Cuda_jim's Avatar
Cuda_jim
Cuda_jim is offline
Welcome Nick, the manual Jim posted above has a ton of info but it doesn't have everything you might need.
The Trans Control Switch (TCS) is the official name in case you need to order parts.
Here's a diagram
Old 07-06-2010, 12:28 PM
Az.Nick's Avatar
Az.Nick
Az.Nick is offline
THanks for the welcome.
I looked at what you guys provided but it doesn't give the color codes, is there any onther options or thoughts on where to find this?
Nick
Old 07-06-2010, 01:09 PM
Hussler's Avatar
Hussler
Hussler is offline
Color codes are in the above link I provided. For example ...
R/Y = Red with yellow stripe
W/LG = White with light green stripe
Old 07-06-2010, 01:17 PM
Az.Nick's Avatar
Az.Nick
Az.Nick is offline
Ok, so that would be the 4th diagram for the F-series, correct?
Old 07-06-2010, 01:32 PM
Hussler's Avatar
Hussler
Hussler is offline
On mine it's the third from the top, but I have the Heavy Duty. If one of your wires is pink with orange stripe then it's the forth as you indicated.
Old 07-06-2010, 01:46 PM
Az.Nick's Avatar
Az.Nick
Az.Nick is offline
This is on a 1 ton, so it just might be the same as yours. I will check when I make a trip over to where it is. I really appriciate you guys giving me a hand. I'll be in touch.
Nick
Old 07-06-2010, 01:49 PM
Hussler's Avatar
Hussler
Hussler is offline
Nick
Cool ... ...
Epicduder
1999 to 2016 Super Duty
07-17-2020 06:26 AM
nrbacarl
04-04-2016 01:26 PM
nick_lozier
03-08-2012 08:19 PM
shawbran
06-02-2011 09:23 AM
Az.Nick
07-04-2010 10:38 AM
Quick Reply: 1996 F super duty- O.D. wiring diagram
