Magnefine Inline trans filter Any good? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-04-2010, 03:01 PM
racincowboy racincowboy is offline
racincowboy is gaining momentum as a positive member of FTE.
I am considering installing a Magnefine inline external trans filter.
The question I have are they any good?
Any risk of cooking the trans if plugged?
Is it really necessary?
Or is it just better to keep my services at 25k and leave it at that?
Thanks for the help guys
Lance
Old 07-04-2010, 03:02 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Do both.
You can't have "too clean" transmission fluid.
I have taken it one step further and added a spin-on type filter with added neodymium magnets, but MagneFine is an easier way to go and has Ford's blessing. They send one out that MUST be installed with each Ford re-manufactured transmission.
They come in three sizes. 5/16, 3/8, and 1/2 inch. Our SuperDutys are 3/8".
I believe they are also ideal to use in power steering applications (but I put a spin-on there, too).
Pop
Old 07-04-2010, 09:30 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
As Pop said. Ford MANDATES the installation of a Magnafine with any transmission replacement. Of course that has more to do with trapping any metal parts that may have been left over in the lines or cooler from whatever event caused the tranny replacement in the first place, but that doesn't change the fact that it's a good filter to stick in there.
Old 07-04-2010, 11:45 PM
big poppa's Avatar
big poppa big poppa is offline
big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.
That Magnafine filter sounds like a nice added feature for protection like Chris and Pop said but I'm eyeballing that filtering setup Bob at Dieselsite has, its more money but not only having to change out the filter but be able to do clean trans flushes per his shutoff valves, I like that kit alot, probably my next investment.
Old 07-04-2010, 11:57 PM
Waynenap's Avatar
Waynenap Waynenap is offline
Waynenap has a good reputation on FTE.Waynenap has a good reputation on FTE.
Quote:
I just bought a couple of them on ebay tonight. Chump change in comparison, really. I'll put one on the power steering return line for sure. And maybe one on the transmission as well till I can get the kit from Bob that I've been eyeballing as well.
Old 07-05-2010, 12:09 AM
big poppa's Avatar
Quote:
Might have to look into a couple of those filters, can't have enough protection, I'll put one on my wifes Expy..
schlepprock250's Avatar
schlepprock250 schlepprock250 is offline
Guns Dont Kill People..
schlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to behold
...sorry guys,I know the risk/issues that come with doing a flush in our trannies,(mine has 200,000 and I don't know how long its been since it was changed)that being said, if the fluid still looks good and doesn't smell burnt,would my trans.see a benefit of adding a good external filter like the one Dieselsite has,instead of changing the fluid?I know new fluid don't kill our trannies,but I do know transmission fluid is a detergent and removing the old stuff and adding new means theres a more powerfull detergent in there.Mine shifts good and solid,I have a BTS valve body,and a 6.0 cooler,I would like to change the fluid,but I can't afford a new trans either(worse case scenario)...Thoughts.....
Old 07-05-2010, 12:56 AM
big poppa's Avatar
At the very least Phil I would change the fluid, not nesesarily a flush, although IMO would be better for your trans, get the gunk out, just change it out with some fresh fluid, Mercon compatable. I just changed mine out this morning with some Vavoline Max Life Syn. and took it for a test ride and I could feel the difference, smoother right to the point shifts if you catch my drift. I'd do it.
Old 07-05-2010, 11:29 AM
Yeah Mike,I want to and think I will.Towing the TT this year the shifts feel pretty good,temps stayed around the sweet spot,the fluid is not that dirty,but it's a little dirty.I know the stories of new detergent fluid cleaning out the build up and then losing the tranny shortly after that,but I know thats because it was on borrowed time before that and I guess I would rather at least expect it,on my terms right...LOL....Thanks
Old 07-05-2010, 02:13 PM
Well from the sounds of it I should go ahead and order a few. One to install and then a few for my inventory of spare parts.
Mark K. any thoughts? Good, Bad or otherwise?
Transmission cooler line size Buck268 2009 - 2014 F150 1 09-17-2015 08:35 AM
Magnefine "inline" filters joe blow 6.0L Power Stroke Diesel 36 12-11-2013 04:53 PM
Where are the tranny lines? Installing inline filter, have questions. Studawg 1999 - 2003 7.3L Power Stroke Diesel 10 04-10-2012 03:06 PM
Remote External BM Transmission filter Hondaonda 1999 to 2016 Super Duty 3 02-09-2012 08:42 PM
MAGNEFINE transmission filter fallingdown Escape & Escape Hybrid 4 08-25-2009 10:43 AM
Tags
2005, external, f150, f350, filter, ford, inline, install, installing, line, magnefine, output, ranger, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
