GT-40 heads
GT-40 heads
ok guys i am needing a list of what all vehicles came with GT40 heads. im going junkyard hunting this next week. this is the list i know of..
Mustang Cobras 94-95s
F150 Lightnings 93-95
Explorers ? on years
are there any others im missing???
if yall could also fill in the blank on the years the explorer 5ohs came with them.
on
It's a marine engine bought from a marine distributor 6 years ago. I assume it is like HO but hoping some of the Gurus will chime in and tell me some about it and maybe answer you as well. It is supposed to have a 4 bbl on it but all I had was a 2 bbl intake and carb. And wondering if this is going to screw me if the ports don't match. Or do they?
on
No.. head casting numbers are on the lower(head gasket) side between the central intake ports, so the intake has to be off to see it with the heads mounted. As stated the mid '80's 351HO didn't get anything special for heads.. usually the regular production E5TE truck head.
The Explorer 5.0 got the GT40 head in '96 and part of '97 only, after that it got the GT40p version.
the second pic is hard to see. but its D8 something. but thats on the bottom of the head below the exhaust ports.
on
Heads could have been changed at some point or you got an early motor, in any event the '78 head is essentially identical to the '85 head and neither are anything special. Earlier heads did have some identifying casting numbers on the top surface as well but that practice seems to have stopped in the '80's somewhere.
ok..... so........ i just talked to a friend of mine, he thought he had some GT40s and he checked and didnt. but....
he did have some DO 1970 heads that had been reworked to run with out leaded fuel.
they have been sitting for a while so what would need to be done to have them run with out issues on EFI?
on
Are they 302 or 351 heads? These should have "302" or "351" cast into the top surface around the rockers somwhere, and the difference is the 302 version has 58cc chambers and 1.78"/1.45" valves while the 351 has 60cc chambers with 1.84"/1.54" valves. If they are complete with valves and springs they're a decent upgrade but if you have to buy valves don't bother, you can have CNC ported E7's that will easily outperform these for $600 from Powerheads or Thumper Performance!
