Axle ratio?
Axle ratio?
Since I bought my expy used, how can be certain what gear ratio I have and what type of axles the truck has? I'm thinking of adding lockers front and rear. Would this be a good or bad idea?
Thanks
Big Mick
1997 Expedition XLT
K&N Air Intake
Hellwig Anti sway bar
Flow master
Plus extra mods.....
Thanks
Big Mick
1997 Expedition XLT
K&N Air Intake
Flow master
Axle ratio?
Look inside the driver's side door.
Axle Codes:
19-3.55 non-limited slip
17-3.31 non-limited slip
H9-3.55 limited slip
H7-3.31 limited slip
H6-3.73 limited slip
I don't know why you'd want to install lockers unless you use the vehicle in very rough, slick, sloppy terrain. Sure they are cool but do you really need them? Only you can answer that question.
Axle Codes:
Redneckfordf2502002
1997-2006 Expedition & Navigator
11-15-2012 01:57 PM
64_f100_owner
03-03-2004 08:40 AM
