how to drain fuel? - Ford Truck Enthusiasts Forums
how to drain fuel?
Old 07-04-2010, 10:49 AM
wickedklown83's Avatar
wickedklown83 wickedklown83 is offline
wickedklown83 is starting off with a positive reputation.
how to drain fuel?
ok guys i swapped the engine from my 90 f250 into my 89 f250... both 351's... one is a zf trans.. the other was a E4OD... got it hooked up yesterday, tried to crank it... it sputted for a secong and now nothing,, i think the gas in the truck is not good enough to run... i was wondering if there was a easy way to disconnect the fuel line and jump something so the pump will run and i can drain all the old gas... so my question is is there a relay i can jump to make it run continiously until i undo the jump on it?? also would it have any troubles running the 90 engine off the 89 computer??
also i am going to rent a fuel pressure tester now so i can test my pressure also.... also gonna check for spark (even tho i dont see that being an issue beings that it ran in the other truck... just looking for a few ideas so when i get back i can hopefully get this thing to fire up today
Old 07-04-2010, 11:10 AM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
There is a drain plug on the bottom...just unscrew it.
Old 07-04-2010, 12:19 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Unplug the electrical plug on the high pressure pump.
Unhook the pressure fuel lines from each tank where they go into the fuel selector valve by pulling out the hair pin clip and then pulling the hose off and sticking the hoses into 5 gal buckets.
Jump pin #2 to pin #6 of the self-test plug, select the tank to pump from and turn on the key.
I have never seen a drain plug on a fuel tank.
Old 07-04-2010, 12:46 PM
neither have i seen a drain plug on a fuel tank.... thanks subford.... i gotta play a little bit first and see if i can get a pressure reading.... by the way where is the inertia switch and fuel pump relays on these anyways??
Old 07-04-2010, 12:55 PM
subford's Avatar
Inertia Switch:
EEC & Fuel Pump relays:
Old 07-04-2010, 10:33 PM
yeah the relay i seen as soon as i looked and thought about it for 2 seconds lol.. thanks tho, i didnt know where the inertia switch was, even tho in my case it wasnt the issue... the fuel tank selector valve was shot and not letting any fuel through whatsoever.. didnt think it could completely clog up, but it managed to... anyways pulled it out and just jumped the lines for the rear tank. now with its new engine, clutch, and rigged fuel lines it actually runs now,,, now i just got a hundred other things to work out, dont worry you all will be hearing from me soon enough about help on other issues lol
Old 07-04-2010, 10:54 PM
86F150302's Avatar
86F150302 86F150302 is offline
86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.
Subford you deserve alot of rep points. I cant give ya any right now though but as soon as I can again you will be getting some. I have to W **** myself around some more until I can give to quite a few people that deserve them..
In tank fuel pumps randomly shut off?! nova801428 1987 - 1996 F150 & Larger F-Series Trucks 8 12-28-2016 12:25 PM
No Fuel Pressur at Start, Low Pressure under load Sandman94F150 2004 - 2008 F150 5 08-08-2015 11:13 PM
HFCM or HPFP Issue? sailmfast 6.4L Power Stroke Diesel 12 06-08-2015 10:57 PM
2002 F250 Gas V10 No Fuel Pressure Not Starting Please Help! Joel351 1999 to 2016 Super Duty 29 01-04-2012 08:26 PM
Weird fuel pressure problem 1989 F250 5.8L TexasWren 1987 - 1996 F150 & Larger F-Series Trucks 3 07-19-2010 02:40 PM
Tags
1999, 2000, 2006, 95, bad, drain, expedition, f150, f250, ford, fuel, gas, main, ranger, relay, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
