second row seat locked down - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 07-04-2010, 09:56 AM
jmbaker3 jmbaker3 is offline
jmbaker3 is starting off with a positive reputation.
my second row bench seat wont return to the up position. Looks like the latch is hanging up when I compare from seat to seat in that row. any suggestions
Old 07-04-2010, 12:27 PM
angelsndevils angelsndevils is offline
angelsndevils is starting off with a positive reputation.
Move both front seats forward to let pressure off of the second row. This happened to me when I first got mine.
Old 07-04-2010, 12:56 PM
Quote:
Thats what I did to finally get it to move, but still dont think the latches are working properly.
Old 07-04-2010, 04:18 PM
Excursion Gary's Avatar
Excursion Gary Excursion Gary is offline
Excursion's 4ever!
Excursion Gary has a good reputation on FTE.Excursion Gary has a good reputation on FTE.
Put a small amount of silicone based lube release gears if it feels like it's hanging up. I always have to move them around a bit to get mine to release also. But is easier with a small amount of lube.
Old 07-04-2010, 05:04 PM
mark996's Avatar
mark996 mark996 is offline
mark996 is gaining momentum as a positive member of FTE.mark996 is gaining momentum as a positive member of FTE.
Are both seats designed to slide forward or just the smaller one?
Old 07-04-2010, 09:36 PM
TexasEx TexasEx is offline
TexasEx is starting off with a positive reputation.
Pull up on the black side lever and force them up. They will come.
Old 07-05-2010, 07:18 AM
chazman chazman is offline
chazman is starting off with a positive reputation.
Quote:
both should slide forward.
Old 07-05-2010, 11:14 AM
joenmell's Avatar
joenmell joenmell is offline
joenmell is starting off with a positive reputation.
Were you ever able to get the seats up? What did you have to do?
Old 07-05-2010, 11:52 AM
Quote:
Yes, I got the seat up... moved the front seat forward, but still had to push the flipped portion forward... cant believe that just a small amount of pressure against it prevented it from coming up. I really think it needs to be lubed , but not exactly sure what to lube. Have to get truck in for service and will bring to their attn. Never had this probelm before.
Old 07-05-2010, 06:57 PM
joenmell's Avatar
Thanks for the info. Keep us informed if this could be a ongoing problem.
Old 07-05-2010, 07:05 PM
mark996's Avatar
My seat was stuck, the 60 side, so I pulled it forward and pushed pretty hard on it, it sprung forward, I greased it, works wonderfully now, greased the other side while I was at it.
Second row seat velcro azvazquez Excursion - King of SUVs 42 02-02-2017 08:40 AM
Removal of Middle Seat In Second Row hookd 2007 - 2014 Expedition & Navigator 45 08-11-2015 02:45 PM
WTB Excursion 2nd Row Buckets Devilmanak WTB - Parts & other 1 04-08-2013 12:46 AM
Extending 2nd row seat tracks Ell Excursion - King of SUVs 3 12-03-2011 09:28 PM
Does a 4x8 sheet of plywood fit? Snowseeker Excursion - King of SUVs 35 11-14-2010 08:04 PM
Tags
2003, 2nd, excursion, f250, ford, lever, lock, moves, position, rear, return, row, seat, seats, stuck, suv, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
