anyone else do this to their hatch?
Old 07-02-2010, 12:51 AM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
diesel-fitter-bum01 is offline
My back glass was rattling and annoying me. So I took some black electrical tape and wrapped the bars where it hooks onto. Solves the problem for a pretty long time. It's nice. Just wondering.
Old 07-02-2010, 06:12 AM
ZBIGBIG19TH's Avatar
ZBIGBIG19TH
ZBIGBIG19TH is offline
I'm trying too visualize how did you wrap it and can't get to any ideas.
You wrapped the supports? how?where?
Old 07-02-2010, 10:56 AM
diesel-fitter-bum01
The metal bars where the hatch comes down and latches to the truck. Ya only need to wrap it a couple times not many.
Old 07-02-2010, 02:06 PM
TXSailor's Avatar
TXSailor
TXSailor is offline
I'm gogin to try this on the doors as well. I added the "foam backer rods" into the rubber molding and it helps tighten them up alot but now when it does rattle , it's VERY annoying. This might quiet them down.
D
__________________________________________________ ____________________<O</O
Moby D (Great White Whale) -2002 Excursion Limited 4WD 7.3L PSD; 3.73 LS; Edge Evo 2, BFG All-Terrain KO, 4" MBRP TurboBack W/5" Tip, AFE Stage 2 w/Pro 7 , Hellwig, V-codes, Rancho Shocks, towing Airstream 25FB w/ Reese Dual Cam & 1200# bars.
Old 07-05-2010, 06:04 PM
mark996's Avatar
mark996
mark996 is offline
You wrap the hydraulic lift? Not the actual metal rod and goes in to the housing but the black housing itself correct?
Old 07-05-2010, 06:21 PM
bcrewcaptain's Avatar
bcrewcaptain
bcrewcaptain is offline
I believe they are talking about the actual D shaped part of the latch, the fixed portion. Sounds like there is some slop in the alignment of the door and the tape is filling the gap. I tried the same thing on my old Daytonas hatch, it worked...well..until the tape came apart from the wear and tear and the small pieces got caught in the latch and it would no longer lock on and had to be replaced..
if the couple wraps of tape fix it, a minute adjustment on the door will do the same thing and is a lot cheaper than a new latch...
just my .02
Old 07-05-2010, 07:26 PM
gogriz2009's Avatar
gogriz2009
gogriz2009 is offline
How would you adjust the door? The rattle is driving me nuts on the dirt roads.
Old 07-05-2010, 07:53 PM
aortizexcursion's Avatar
aortizexcursion
aortizexcursion is offline
For those of you still confused, the OP simply taped the striker.
Old 07-05-2010, 07:56 PM
bcrewcaptain
one thing to try using that would prob work better would be brush on tool handle coatings...only drawback I could see would be the hatch releasing...but it's not like it's going anywhere
Old 07-05-2010, 08:25 PM
diesel-fitter-bum01
Yeah I believe its called the striker. They are mounted solid to the truck. It's maybe two inches or less of tape I use. I haven't had to change it out for six months now. Depends on where I drive.
Old 07-05-2010, 08:27 PM
diesel-fitter-bum01
Didn't get the picture the first time, but yeah that's what I wrap.
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: anyone else do this to their hatch?
