E40D line pressure check - Ford Truck Enthusiasts Forums
Old 07-04-2010, 04:41 AM
drivembig's Avatar
drivembig drivembig is offline
drivembig is starting off with a positive reputation.
Hi, I'm having a problem with my E40D (big suprise huh). Reverse engages fine, but sometimes (not always) when I shift into D the truck just revs up and will eventually start pulling. If I shift it down into 1 when this is happening it will engage and go.
I know that 1 runs a higher line pressure than D does, so I am assuming that maybe the line pressures are low. I found this on the web and was wondering how I could check my pressures?
At idle,
P.55-65
R.75-99
N.55-65
D.55-65
2.55-65
1.75-99
If I do find line pressures low, does that mean that the pump is bad? I had a new Torque converter and a shift kit installed a few months back. Could this be something caused from that?
Any help would be greatly appreciated. I'm getting ready for a trip pulling my 5'r for the first time and don't want any issues because of the junk E40D. Thanks in advance.
Old 07-04-2010, 05:17 AM
Cuda_jim's Avatar
Cuda_jim Cuda_jim is offline
Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.
Everything you need is in the link......online shop manual.
1996 Bronco/F-Series Workshop Manual
Old 07-04-2010, 07:01 AM
drivembig's Avatar
WOW....thanks for the great link there. A lot of usefull info in this one....
Old 07-04-2010, 07:32 AM
DRRXR's Avatar
DRRXR DRRXR is offline
DRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputation
Probably time for some updates or MSRP connector check.
An Introduction to the E4OD Transmission - Baumann Electronic Controls, LLC
Old 07-04-2010, 07:34 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Quote:
If line is low in every position, then it probably is the pump. If it is fine in some and low in others you have leakage in the circuits that are pressurized when the pressures are low.
Old 07-04-2010, 07:44 AM
DRRXR's Avatar
Old 07-04-2010, 08:42 AM
drivembig's Avatar
Quote:
Well that kinda makes since to me. Reverse engages very well and pulls very well. When I shift into D I never really feel it engage like it does in Reverse.
When I had the shift kit installed, I wonder if maybe the tranny guy didn't get the valve body tight and sealed properly.
He had a computer that he hooked up when I first took it in and it would read the line pressures, the shift commands and many other things. I is a really nice computer. I think I will take it by there on tuesday and have him hook it back up and drive it down the road and see what we find.
This didn't start happening till he worked on it. If the pressures were low, shouldn't it be setting a DTC?
Thanks for all the responses and the help. This forum is got to be the best on the web.
Old 07-04-2010, 08:46 AM
DRRXR's Avatar
You would think so. So they did a shift kit too. Okay did they replace the cooler too?
Old 07-04-2010, 12:23 PM
The PCM doesn't know what line pressure is. It only knows what it tells the pressure control solenoid to set line pressure at. It could be commanding 200 PSI and you may only get 50 PSI and the PCM won't know that.
If you take that chart and compare line pressure in the computer it will be right every single time, whether or not line pressure is correct or not.
Old 07-05-2010, 04:02 AM
drivembig's Avatar
Quote:
Which cooler do you mean? Are you talking about the cooler in front of the radiator? If so, its the same one that was on there when I got the truck.
Thanks.
Old 07-05-2010, 07:26 AM
DRRXR's Avatar
Thanks.
The transmission cooler near the radiator. It should have been replaced when the other work was done. If it was a internal trans cooler (in radiator) tubes should have been pulled and a external high effeciency cooler tied to the tubes. Then bull plug the ones at the radiator.
Fines can get trap in there and recirculate back to the pump and valves. There is no way to clean them right.
Old 07-05-2010, 05:05 PM
drivembig's Avatar
Yea, I already have the external cooler. Thanks for the help
Old 05-25-2011, 04:27 PM
Cratos's Avatar
Cratos Cratos is offline
Cratos is starting off with a positive reputation.
what should the line pressure in the cooler lines be ? i see 30 with out any cooler hooked up just loop the lines with a t fitting for a pressure gauge.
Old 05-25-2011, 08:57 PM
The pressure in the cooler lines should be around 15-30 PSI.
Line pressure is a name for a specific pressure in the transmission. Line pressure isn't found in the cooler lines.
Old 03-06-2016, 04:17 PM
Corey Wampler Corey Wampler is offline
Corey Wampler is starting off with a positive reputation.
At idle,
P.55-65
R.75-99
N.55-65
D.55-65
2.55-65
1.75-99
I am having the exact same problem with my 96 F-250 7.3 E4OD. Did you ever get your problem resolved? If so how did you resolve it?
Fuel Pressure problems? Auber Instruments Gauge ExPACamper 1999 - 2003 7.3L Power Stroke Diesel 130 03-16-2016 05:57 PM
MAP sensor? vintagequest 1987 - 1996 F150 & Larger F-Series Trucks 5 01-20-2016 05:02 AM
TIRE PRESSURE mapmanLI Excursion - King of SUVs 16 04-15-2013 03:52 PM
Skipping 6.7 diesel? Bdove 6.7L Power Stroke Diesel 17 05-13-2012 03:54 PM
Trans line pressure question Hiflyer746 1994.5 - 1997 7.3L Power Stroke Diesel 13 12-15-2009 05:46 PM
Tags
1996, 200psi, 73, check, drive, e40d, e4od, f350, high, line, location, pressure, pressures, size, specification, tranny, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
