1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Grinding when Disengaging 4x4 LOW
Old 07-03-2010, 10:12 PM
Jayybird's Avatar
Jayybird
Jayybird is offline
Hi,
I have an 05 F250, Fx4, 6.0. I have been hearing some grinding either at the front end or at the transfer case when i disengage from 4x4 LOW. It doesn't do it everytime. When i click her out of 4x4 low and shift into gear I hear the grinding noise...like something is in a bind. When using 4x4 low range i do shift in and out while tranny is in neutral. Both times i've heard this grinding noise i was on a very slight grade (not sure if thats why). Does anyone know what would cause this?
Thanks for the help, any input is appreciated.
Old 07-03-2010, 10:16 PM
EXv10's Avatar
EXv10
EXv10 is offline
Do you stop, put it in neutral, press on the brake, then take it out of 4x4 low?
Old 07-03-2010, 10:31 PM
Blujay96's Avatar
Blujay96
Blujay96 is offline
I have found sometimes it is better to put it in reverse if you were going forward to take the pressure off the gears, then shift into neutral and disengage.
Old 07-03-2010, 10:41 PM
lakewood's Avatar
lakewood
lakewood is offline
I have an 05 also, never had problem disengauging from 4 lo, have you changed the tranfer case oil or the front axle oil? I bought my truck at 82k miles, changed the tranfer case oil at 93k and it came out black, i think the previous owner never changed it, because it should be red...
Old 07-04-2010, 02:41 AM
redford's Avatar
redford
redford is offline
Received 1,550 Likes on 905 Posts
Are your hubs locking properly? Are they unlocking properly?
Are you complete stop when shifting in and out of 4L?
Old 07-05-2010, 08:07 AM
Jayybird's Avatar
Jayybird
Jayybird is offline
Thanks for all the suggestions, you guys are awesome! I will definitly try this (quote above). Other than that, I do everthing else you guys have mentioned. One thing that may be contributing to the problem, the diffs and crankcase have never been serviced on this truck (127k miles). I'll be doing that ASAP. I will post back if this seems to fix the problem.
Thanks
aksnopro2
11-11-2015 11:55 PM
MRTQV10
Modular V10 (6.8l)
01-14-2013 10:56 AM
zrt600guy
12-01-2009 09:36 PM
maguyver
2004 - 2008 F150
09-26-2008 06:18 PM
Mr.Russell
2004 - 2008 F150
08-07-2008 10:20 PM
Quick Reply: Grinding when Disengaging 4x4 LOW
