Could I really need 8 new injectors?
I've been thinking I have a fuel pressure problem, so i changed the ICP sensor and put a fuel pressure gauge on my filter housing to monitor fuel pressure while driving. The pressure stays at about 54 psi and drops to about 48 psi at WOT, then jumps back up after a second or two. So i brought it to a mechanic to check it out. He seems to think ALL my injectors are scarred from a lack of fuel pressure at some point in the past. The truck doesn't throw any codes and i now have a TS Performance chip on it and on the highest setting (140 HP), the truck actually feels like it's starving for fuel and doesn't throw much smoke. On any setting less than that, there isn't any smoke. Oil, air, and fuel filters are all new. The truck has had the in-the-tank-filters removed before i bought the truck.
Any thoughts would be appreciated! I'm just not sure if $3500 for 8 new injectors is actually going to fix my truck. The truck runs great as far as start-up, idle, and driveability. It's just noticeably sluggish compared to 2 other identical bone-stock company trucks I drive at work.
https://www.ford-trucks.com/forums/9...r-mystery.html
Did he use the Magic 8 ball from the 70's for his analysis? Wow.
If your fuel pressure is low, I first have to ask: what location are you using to get your measurements? Our trucks typically are happiest around 65psi, so maybe you could start with a new fuel pump first. Get your fuel pressure up to 65ish first and go from there.
Unless you fuel pressure has been lower than that you should be fine. 48psi is with in Fords specs for these, 52 psi +/- 4psi.
Have you been experiencing any other issues, or just "lower" fuel pressure?
I find it hard to belive I need 8 when the truck runs as smooth as it does. It's just lacking power. I haul my tractor that weighs about 12500lbs including trailer and the truck can barley keep it going 70mph in overdrive and my company truck {01f2504door2wheel-bone stock} will pull it all day 85&90 without breaking a sweat. So I dont know what to do.
Sometimes when Ive been running my truck hard it feels like when I'm laying into the throttle to pass someone the truck hesitates and then starts taking off after a couple of seconds and acts like it should. I really feel like this hesitation issue could be my problem if I could figure out what is causing it.
Have you seen your fuel pressure when that happens?
If the fuel pressure isn't dropping then I think we might rule that out. Those pressure won't hurt anything. If you want to completely rule it out you can shim it up to 62-65 psi.
So at this point it seems to be a lack of power? No codes or anything?
Can you reference me or tell me how to shim it. Right. The only time I've gotten a code was when Ihad the chip on and would not get out of the throttle. it said somethig like pressure higher or lower than recomended. Not sure exactly if thats right. Never any codes when set to stock. The mechanic did say that after driving the truck for a while the boost was only getting up to 13psi and Ive already cheked for leaks on intake and exaust side
