You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Year: 2002 Make: Ford Model: F-150 Price: $5500 Mileage: 250000 Color: White Private or Dealer Listing: Private Listing Location (State): MS Transmission: Automatic Drivetrain: 4WD & AWD Color: White Engine: 5.4L
2002 Ford F150 FX4 XLT, 5.4L V8, Automatic, 4x4, standard cab, short bed, limited slip rear diff, drop-in bed liner, JVC CD Player w/ remote, tow package, tinted windows, nerf bars, cold A/C, power windows and locks, keyless entry, storage box behind seats, interior in good condition, new 33” Maxxis Buckshot mudders on American Eagle wheels, tailgate equipped with torsion bar for easy lift, bed stake pockets equipped with tie downs, computer was custom tuned by previous owner, K&N air filter, cat back exhaust, new windshield.
250k miles on truck, 115k miles on engine. Comes with some spare tune up parts from when engine was replaced. The engine was installed about 2000 miles ago. At the time, the water pump, belt, spark plugs, exhaust manifold gaskets, intake manifold gaskets, dpfe hoses, fuel pump, fuel filter, and battery were replaced. Battery is 1000 CCA. Cooling system has been back flushed, and thermostat and radiator hoses replaced. Engine is equipped with block heater, but I don’t have the cord to plug it up, but it is dealer available for about $40. All 4 brake rotors, front and rear brake pads, emergency brake shoes, and front left brake caliper were replaced, old brake fluid flushed and replaced with fresh synthetic. Rear differential has recently been serviced and rear pinion seal replaced. Several components of the front end were replaced shortly before I bought it by the previous owner. Front valance was removed due to being broken, but it’s an inexpensive replacement part. Have factory fog lights that were removed when valance was removed. It has cruise control, but the servo tests bad. Used ones are available for around $50 if you need cruise to work.
Note that even though this is an XLT trim truck, the floor mat is factory vinyl and the transfer case is manual shift on the floor. The seats are 60/40 split cloth. All the spare tire equipment is still on the truck with a new spare holder under the bed, and the owner’s manual is still in the glove box. Transmission, transfer case, and both differentials are tight, front end components are tight. Solid, reliable transportation or good weekend wheeler that drives and handles well. Have receipts for all work that has been done. Must see and drive to appreciate. $5500 Firm. Call 601-850-6186.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
