Nameless Project - 1995 Ford F150
#33
#34
35 spline dana 60 drive flanges.
upper link tower
Steering drag link.
Measuring for track bar bracket.
Roughing out track bar bracket.
Stick welding FTMFW!
It certainly won't win any design awards, but it should hold up..
Track bar bracket mostly finished.
Checking link, track bar, and steering clearance.
Approximately where the coilovers will be. Just getting an idea for clearance.
I'm still considering moving the location of my upper link to under the frame rail. if I do, I'll gain 3" of uptravel on the passenger side.
upper link tower
Steering drag link.
#35
#41
Okay, okay, fine... no pics though, but a little info...
I ordered the 35 spline side gears for my dana 60 detroit locker. I should be ordering my bw1356/np205 doubler within a few weeks as well. I'm also planning on calling Poly Performance and getting my coil springs for the coilovers ordered very soon. Still trying to decide exactly what spring rates I want to go with. I've been sketching out ideas on how I want to rebuild my transmission crossmember. I'm not happy with what I currently have. I'm going to have it bolt to the inside of the frame, tuck up a little higher, and be a skid plate. Plan is to flatbelly the truck. I'm also planning on shortening and moving the upper link to under the frame. Where its at right now, it will hit my o2 sensor when stuffing tire on the passenger side. I want to get my truck sittin' as low as possible. 5-6" up travel, 10" down travel is the goal.
I also have a few ideas in mine for how I'm going to build my upper coilover towers. I do know that I want them made out of plate steel, not tubing. Shouldn't be too hard. I just am fine-tuning the design in my head, so it doesn't look like ***.
#42
#43
#44
#45
