2000 Ex turn signal relay location - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 07-02-2010, 11:27 PM
Bearmo01's Avatar
Bearmo01 Bearmo01 is offline
Bearmo01 is starting off with a positive reputation.
Hey Guys,
I must be really freakin' stupid, but I have searched the other posts on here, but I still cannot locate where my relay switch is for my turn signals. I have some LED bulbs I put in and want to correct the hyperflash issue.
I have a new relay (EP27) I see some relays to the left of the steering wheel in the the fuse panel box, but in searching other posts I read where its located to the right of the steering column tucked back up in there. I've removed the insulator panel around the brake pedal but damn if I cant find it still. I've felt around up in there, but I dont want to just start yankin' on stuff.
Man, I wish it were the ones in the fuse panel box, I would have been done an hour ago.
Any tips or suggestions would be very appreciated...thanks in advance!
Bear
Old 07-03-2010, 04:08 AM
Shepherd2 Shepherd2 is offline
Shepherd2 has a good reputation on FTE.Shepherd2 has a good reputation on FTE.Shepherd2 has a good reputation on FTE.
Well the schematic shows it being in the instrument panel relay block which is listed as near the center of the dash but when you look up the relay location it's listed as being in the LH side of the I/P. Typical Ford manuals. If it's working I just turn on the signals and listen for the clicking.
Old 07-03-2010, 04:59 AM
Bearmo01's Avatar
Good idea, I'll give it a listen.
Thanks Shep
Old 07-05-2010, 10:12 PM
Bearmo01's Avatar
Well, I finally got it done yesterday. I ended up removing the lower portion of the dash, pretty easy too, only 8 screws held it in place. Once that was off, the relay was right there, easy swap. The LED's are flashin' at normal speed. It's a pretty cool, inexpensive upgrade. I did my front and rear flashers, and also the parking lights. Next mod this week is limo tint on all the windows. Next up in a couple weeks or so, is adding some fogs or some LED DRL's.
1996 Explorer XLT - trailer light problems EricExplorer Explorer, Sport Trac, Mountaineer & Aviator 10 11-03-2014 08:08 PM
Location of turn signal relay 1996 F150 XLT medicanic7 1987 - 1996 F150 & Larger F-Series Trucks 5 06-09-2013 06:22 PM
Whats the location of turn signal flasher on 03 F250 5.4 BBBSS 1999 to 2016 Super Duty 2 10-07-2011 12:16 AM
A fun instrument panel light problem on a '99 F250 Super Duty PSD JPdiesel Electrical Systems/Wiring 5 09-16-2011 12:06 AM
'99 7.3, Electrical issues JPdiesel 1999 to 2016 Super Duty 7 09-15-2011 11:11 AM
Tags
05, 1996, 2000, 2002, aerostar, duty, excursion, f250, f350, ford, fuse, location, relay, signal, super, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
