52 F7 Battery Cover - Ford Truck Enthusiasts Forums
52 F7 Battery Cover
Old 07-02-2010, 10:06 PM
MP&C's Avatar
MP&C MP&C is offline
MP&C has a good reputation on FTE.MP&C has a good reputation on FTE.MP&C has a good reputation on FTE.
52 F7 Battery Cover
One of the pieces missing from my truck when I got it was the inside battery cover to fill the hole in the floor. I happened to borrow one today from a local guy so I could fab one up, so here are the details for anyone else in the same predicament.
This is the sample piece. Cut the new one out of a piece of 16 ga CRS, the bend relief slots were formed with a 1/16" cutoff wheel..
The fancy radius tool uses a 1-3/8 socket
The bend is inside the relief slots, which would make this more difficult with an apron brake, but I suppose one could flatten the outer ears back out if need be. I used my press brake, had the right amount of lower dies for the exact length, but not the right size for the top. So I slid the upper die back and forth and incrementally bent it up.
Finger pull was marked out, and an 11/16 socket used as an anvil, some hammer work forms it pretty nicely.
.....and a test fit.....
For anyone who has lost their's as well, here's the treasure map. The two holes were letter R size and overall height before bending was the 5-7/16".
Tags
battery cover, f7, ford, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
