Dual Exhaust - One Side Richer than the Other?
I have true dual exhaust/Flowmasters (no cats) on my 1983 F150 with a 302 engine. I have noticed lately that the passenger's side exhaust pipe is running slightly richer than the driver's side. It is most noticeable when the truck is first started, and diminishes as the truck is driven some. The engine was rebuilt a couple of years ago and only has about 2K miles on it. Other than that, my truck runs the same as it always has - FANTASTIC!
I am still learning about carbs. What would cause one side to run richer than the other? Is this a choke issue?
Whew! That shouldn't be too hard to check out! When I got the truck, I tried to adjust the carburetor with a vacuum gauge, but being my first time, I couldn't get it right. I ended up running way rich at idle. With the help of my father-in-law ex-mechanic, we adjusted the idle mixture screws to correct the problem. If I remember correctly, on that side (the rich side) I had the idle mixture screw set a full 1-1/2 turns out more than the other side! Assuming that did foul the spark plugs on that side, would the plugs stay fouled, even if the carburetor was re-tuned?
Idle mixture screw on one side of carb feeds two cylinders on each side of the engine, so evenly affects each side.
Well, more or less... It will affect the side that it feeds the middle cylinders slightly more due to better fuel distribution to the middle two, the 4 end cylinders typically run slightly leaner with msot production dual plane intakes, but that's going beyond the scope of this post.
See, as in black smoke? If it's lighter colored you're see moisture/water vapor that could accumulate more in one side for any number of reasons, inlcluding how you park the truck relative to the sun. If black smoke are you sure it's fuel and not oil? Could indicate bad valve stem seals or rings on one of the cyls on that side.
the exhaust cross over is heating the carb from inside the intake. when first started, the choke being closed/partial closed, will make a rich condition on the passenger side.you would not notice this if you still had cats
Nathan Plemons
37
08-16-2017 08:30 PM
dhickel004
13
01-29-2017 05:39 PM
coleboy11
09-11-2016 01:28 PM
DrZoom
08-31-2016 10:48 AM
zsir
04-02-2006 05:50 PM
