Got my Insight Installed...couple questions
OK...so I just got off the phone with Edge Products. Turns out I'm not quite as 'slow' as I originally thought...
As far as the software not working, it does. I just had in my mind that I should be able to customize what PID's, the background, layout, etc that I wanted the screen to look like, and I couldn't. Turns out, that ability is not supported.
For the PID options...what I wanted to monitor was EGT, ECT, EOT, and boost.
-EGT will show up once I have the probe installed.
-ECT is already there being monitored.
-Boost is not there...yet anyway. They should be releasing an update including Boost within the next 2 weeks. For now, they said use Manifold Absolute Pressure, which should read around 12-13 at idle. Once you hit the throttle, and it reads 18-19, whatever, the boost is around 6psi. In-exact science, I guess.
-EOT sounds like it is not supported, and won't be. I got cut off from them while just beginning to talk about this, and am on hold as I type. If anything further comes from it, I'll keep y'all posted.
Please correct me if I'm wrong...the original Insight was / is able to monitor EOT? Wonder why the 'new' version isn't capable...
-Boost is not there...yet anyway. They should be releasing an update including Boost within the next 2 weeks. For now, they said for now use Manifold Absolute Pressure, which should read around 12-13 at idle. Once you hit the throttle, and it reads 18-19, whatever, the boost is around 6psi. In-exact science, I guess.
Sounds like MAP is not subtracting atmospheric pressure of around 13-14 PSI. Also unacceptable. They MUST fix that if they want to sell those units. Tell them you are sharing this info with FTE, so you want to be sure you are getting the latest info. Good or bad. That should light a fire under them.
Seems like as an early adopter you are getting the runaround while they complete their engineering.
Yes, unfortunately...the damned thing is that I should know better than to purchase something that was just released. Let them work out the hiccups, then purchase...
When I get them on the phone again, are there any other questions / concerns I should be asking about? Anything that anyone on FTE would like to know so I can ask those specifically?
Just got off the phone with Edge, and unfortunately the 'new and improved' Insight CS / CTS use the same limited software. The shortfalls are listed in a previous post...
-boost is coming, couldn't give a date as to when
-EOT is not, and it sounded like it was low on the priority list. However, I'm sure that 'loud voices' and sales will change that perspective...
So it looks like, being that EOT and ECT were two big PIDs I wanted to monitor, I will be sending this back, and going with the orginal Insight...if I can still get one.
That is quite possible, although both times I talked to someone different. I guess there could be two...or more.
It just doesn't make sense to me that the original Insight could do it, but not the 'latest and greatest'. From my understanding, the only thing that changed was a colored screen / touch screen. If they didn't have any problems with the original software / firmware, why change anything??
Those are rhetorical questions...just frustrating...
Amazon.com: Edge Products 83400 INSIGHT Multi-Gauge Display: Automotive
I wonder if the same EGT probe works?
Amazon still has it, and it is right now $50 less than I paid.
The EGT probe is a great question...I will definately need to find out about that.
I received my Edge Insight CS in today from Performance Truck Products; I had no trouble selecting the PID's that you would expect from an Insight (ECT, EOT, Boost, etc). It even read my "soft code" wrench light ... which was a PO12F ). I feel kind'a stupid now 'cause I emailed Edge this morning about this thread with a kind of ticked-off tone as I ordered this specifically for the EOT reading.
Anyway ... what I did out-of-the-box:
1) Smiled real big
2) Installed the Fusion software
3) Installed the MyStyle software
4) Registerd for Fusion access
5) Launched the Fusion software
6) Connected the Insight CS to the computer
7) Let it update (there was no update available)
8) Disconnected and took out to the truck
9) Connected to the OBD
10) Turned ignition to the "ON" position
11) Insight wanted me to answer warning, so I did
12) Insight wanted me to confirm the truck was a Ford, so I did
13) Insight read my VIN
14) Insight displayed the guage screen with the default displayed: Left = ECT, Center = Vehicle Speed, & Right = Boost
15) Went through menu to explore; changed background to American Flag (Hooahh!!)
16) Went back to main display screen, pressed "enter" & got the menu to change the left-center-right PID's.
17) Left the left PID at ECT, changed the center PID to boost (for now, will be EGT in about an hour), & changed the right PID to EOT. - - Temperatures were 102* ECT & 100* EOT (engine hasnt been ran all day, it's been over 100* outside today!)
18) Going out now to install the EGT Probe.
1) Smiled real big
#28
Glad everything worked out for you 98SurplusExpy.
I got a hold of Adam at First Coast Diesel, and he couldn't believe that EOT 'wasn't monitored', so he got in touch with Edge, and I just received an email from Edge stating 'Adam from First Coast Diesel Performance contacted me and stated that you weren’t able to read EOT and that someone at Edge told you we never planned to add this PID to the display list. I apologize for the confusion but this PID should be available to you on your Insight and we believe there might be something wrong with your product.'
Waiting on a phone call, so we will see what transpires...
#29
#30
It took me longer to run the EGT & OBD wires up there than it did to drill & tap the manifold for the EGT probe. It's all working quite nicely. I'll get some pics up maybe tomorrow.
Hope Chris gets his straightened out ...
