F250 Towing large boat
on
I have a 2005 F250 Cab Chassis with the 7.3 powerstroke and want to tow a boat that weighs approximately 8800lbs.
The owners manual that comes with the truck states that if towing loads over 5000lbs and up to 9900lbs that a Ford approved Load Leveling Device must be used.
Can any one tell me if this is correct or if it is just a recommendation.
on
The owners guide say's a Ford approved Load Levelling Kit, to be precise.
Quote" The Ford Approved 3500kg(7700lb) Heavy Duty Towbar may be used to tow a trailer up to 2270kg(4994lb) Gross Trailer Weight using the 2270kg(4994lb) ball mount also supplied. For Gross Trailer Weight greater than 2270kg(4994lb), a Ford approved Load Levelling Kit must be used." End Quote.
It is a bit hard to understand but that is how it is written in the guide.
Also in the guide is a Maximum Towing Capacity table showing all the different models and for my model the rating is 6033kg(13272lb) with a 5th wheel and 4500kg(9900lb) conventional towing as long as a Load Levelling Kit is fitted.
I have an aftermarket Hayman Reese Towbar that is stamped with a SWL of 4500kg(9900lb) but I do not have a Load Levelling Kit.
I just thought that someone out there might of had some experience with these Load Levelling Kits and could tell me if they are in fact needed.
on
JL
BTW I would like to see some pics of your truck if you have some.
on
