Key will not release from ignition following replacements
I have a 2002 Expedition 5.4L XLT 2WD that will not release the key from the ignition following replacement of shift tube, shift interlock solenoid, shift cable and Transmission range sensor. I need to re-adjust the steering wheel as it doesn't feel as tight when turning but it does shift smoothly now. When I place it in park, it sits fine, ignition starts when I turn the key, no rolling back/forward or anything but I am unable to turn the key all the way off and remove it from the ignition switch. I have to pull the ignition switch to remove the key and then turn the truck off with a screwdriver. I would appreciate any knowledge on the matter. Thank you in advance!
Sounds like the Range Sensor isn't adjusted properly. Set the parking brake first. With the ignition in the RUN position (engine not running), put the shifter in the Reverse selection position. Do your backup lights come on ? You may need to adjust the sensor so that they do. Then try the Park position and see if it releases your key and restarts properly.
mpgvan
01-24-2010 10:14 AM
