Tranny fluid leak - Ford Truck Enthusiasts Forums
Idaho Chapter Idaho Chapter
Join Chapter, Leader: im2tall33
Tranny fluid leak
Old 07-01-2010, 06:27 PM
supersle's Avatar
supersle supersle is offline
supersle is starting off with a positive reputation.
Tranny fluid leak
So I towed my car up to Portland and back last weekend. Flawless and not a problem. But when I got to Boise to a friend's house I was backing the trailer into his driveway and noticed I was leaking a line of tranny fluid down his driveway and when I stopped it just puddled up. Let it sit for a while and cool off since I just drove 400+miles on it. Drove forward and no leak. Topped it off and drove 300 more miles home and still no leak. Haven't tried in reverse really other than backing out of the drive and there isn't a puddle under the truck sitting. Anyone have any ideas?
Edit: found a few suggestions searching
Quote:
Pulling in reverse will get the trans hot in a hurry.... The front seal can and does flip causing aleak, it might return to normal after it cools down but, eventually it will fail though. There is a new seal (viton IIRC) that's supposed to cure it.
Old 07-01-2010, 08:04 PM
im2tall33's Avatar
im2tall33 im2tall33 is offline
ID CHAPTER LDR
im2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputation
hmmm? i dont know..i would try posting this in the v10 section and the larger truck sections.. they could deffinatley help you out..seems kinda odd though..
Old 10-15-2010, 09:43 AM
gearhead351 gearhead351 is offline
gearhead351 is starting off with a positive reputation.
Might have started to over heat the trans fluid. Fluid expands as it gets hot. Or did you back up an incline? Slip yoke might have just moved and allowed fluid to pass temporarily until the "load" was taken off the shaft. (thats what she said) ahaha.
Im2Tall I happen to live in couerdalene as well!
tranny leaking very much, now cant get it to do it again. cptaylor 1987 - 1996 F150 & Larger F-Series Trucks 3 06-29-2014 07:19 PM
1981 F250 Transmission cooler? Hotel 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 06-12-2014 07:48 AM
Mystery E40D Issue kenko 1987 - 1996 F150 & Larger F-Series Trucks 5 06-03-2012 04:19 PM
Transmission fluid...leaking? Awitte58 1994.5 - 1997 7.3L Power Stroke Diesel 7 06-03-2011 10:02 AM
C6 Transmission problems... mark73f250 1973 - 1979 F-100 & Larger F-Series Trucks 2 08-31-2004 04:40 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
backing, explorer, f250, fluid, ford, leak, leaking, tranny, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
