How not to change a fan clutch. - Ford Truck Enthusiasts Forums
Old 02-08-2003, 06:15 PM
Ultramagdan's Avatar
Ultramagdan Ultramagdan is offline
Ultramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud of
Post How not to change a fan clutch.
Well my fan clutch has gone out. It is really squealing and I knew I'd better take care of it before it goes through the radiator of my F250.
So I went down to NAPA and got the special tool that is needed to hold the pulley while you wrench off the shaft that has the clutch and fan assembly. Got home and tried to do it myself. I did remember that it is a left hand thread and so applied force accordingly. Tried it several times before I realized I was going to need a cheater and another body. It was at this point my neighbor got involved. Now with my neighbor holding '3 of pipe on the "1/2 breaker bar I tried it again. No go. The 4 letter words are starting to flow pretty good at this point. I just want to take the thing off! It's all my neighbor can do to hold the cheater bar while I apply force to the other "1/2 breaker bar. Dang, this thing is tough! It seems like most break lose fairly easily. Not this one. So I tried it one more time and really put the mustard to it. Just about the time I thought it was going to go..BANG, CLATTER, OUCH!.
The wrench that is used to hold the pulley still had shattered and the "3 piece flew up and nailed me right in the forehead. It left a "1 grove in my forehead and bleed pretty good to.
It was at this point that I realized I could probably pay someone else to remove the damn thing a whole lot easier and safer.
I took the now broken wrench back to NAPA. They refunded my $60 and said they'd never seen one broke before.
The truck goes in Monday.
Old 02-08-2003, 08:48 PM
hyflyer78 hyflyer78 is offline
hyflyer78 is starting off with a positive reputation.
man i hear your pain i was also told that my clutch fan on my 97 f150 4.6 4x4 sc had left hand threads also. after much cursing and a little bleeding i found out that it was RIGHT hand thread it was not backwards. so after that i was able to get it off and i didnt use the special tool just shade treed it. i was relacing my clutch fan with electric fans. so i hope this helps
Old 02-08-2003, 10:00 PM
Right hand threads!!????
Oh for pete's sake.
Well, I wasn't planning on replacing the blasted thing and was just going to run a while without the fan, then this summer install the electric unit like you did.
Guess I'll find out Monday if it has right hand threads.
Radiator fan clutch (thermostatic) replacement. wpnaes Excursion - King of SUVs 4 02-02-2015 12:35 PM
Fan clutch removal, a new trick! akamacgyver Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 04-18-2013 05:41 PM
Fan clutch removal info toolmanx Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 12-27-2011 07:20 PM
Fan clutch removal how to? jlo84truck 6.0L Power Stroke Diesel 5 02-02-2009 07:59 PM
Is idler pulley bolt right hand or left hand thread? Fairlane62 1987 - 1996 F150 & Larger F-Series Trucks 1 07-19-2004 12:17 PM
Tags
1986, 2002, 300, 46l, 96, 97, assembly, bronco, change, clutch, f150, f250, fan, ford, motor, replace, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
