Another A/C thread from AZ
I took some pictures of my set up so hopefully they will give an idea of what I have. Truck has ducting and some in dash components. The only real hint it ever had A/C is the sticker on the radiator support and the fact that the controls say cold as well as hot. Big box in the passenger side under the hood which I assume is for the heater. What do I need to make the A/C work on this thing? I dont have 900 to spend on a new kit. Can anyone tell me if I am just missing parts or if I am just better off biting the bullet and buying a whole new kit for this thing? was thinking about one of these kits.
Ford AC Kits for Trucks
if I have half the parts but can get away with one of the cheaper kits I can do that. I just cant tell what I have. I don't know anything aboutA/C systems except it sucks when you are in a tin box in AZ without one lol
You probably still have everything under the dash and everything inside the evaporator/blower housing (that big box under the hood).
You're missing the a/c compressor and it looks like the hoses are gone too. Can't tell about the evaporator, that goes in front of the radiator along with the drier (round, tube shaped thing next to the condenser).
Here are three illustrations from the Ford parts manual showing the underhood components.
Click on the .pdf link to open the file.
In the first two illustrations scroll to the bottom for the appropriate drawings.
Also it looks like that compressor mounting bracket that the coil is sitting on is upside down. It may just be the way I'm looking at it, my work computer's screen is kinda dark.
I think you got that a little confused by mistake. Just the condenser and drier are up in front of the radiator. The evaporator is under the dash. The easy way to tell if it's still there is if you see two metal tubes coming out of the side of the big box under the hood right next to the firewall.
THanks guys. I think they make a kit with just the stuff I am missing for about 450. I will take the whole thing apart this weekend to make sure nothing else is missing or busted. I dont know how long the stuff has been gone.
Ford Truck A/C Kit - Select an Evaporator - Stock Comp. Mount
does this kit look like it might be right? It is the one the woman on the phone recommended.
crsweet78
143
02-01-2018 11:41 AM
Milwaukee1979F150
1999 to 2016 Super Duty
46
07-06-2010 07:16 PM
