1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Will my leaky manifold cause damage?
Old 06-30-2010, 09:02 PM
06SD250's Avatar
06SD250
06SD250 is offline
I have an 06 250 gas job that has an exhaust leak, I could hear it but couldnt find it so I took it up to midas today and figured they could show me which gasket it was and I would fix it. The mechanic said he cant find it either but my right side manifold looks pretty rough and its most likely leaking from there. I dont have time to pull the manifold off right know and I want to know if I am doing any damage if I drive the truck like this for a while. I was planning on taking it to Maine (about a two hour trip) this weekend. Any help would be great.
Old 06-30-2010, 09:16 PM
bakon's Avatar
bakon
bakon is offline
If you and a mechanic cant find it... maybe it dont exist? I doubt you hurt anything if it cant be located. Would have to be pretty small, BUT...
Old 06-30-2010, 09:21 PM
BareBones's Avatar
BareBones
BareBones is offline
People on the forums report running with broken exhaust bolts for years with no damage. On the other hand, its been said that loose spark plugs ready to blow also sound like a leaking exhaust, and a popped plug can definitely be a problem.....
Old 06-30-2010, 09:29 PM
06SD250's Avatar
06SD250
06SD250 is offline
It definitly sounds like an exhaust leak, it ticks real loud when I start it and then quiets down when it heats up, whenever I drive along side a jersey barrier or wall you can really hear it also.
Old 06-30-2010, 09:34 PM
Pinky Demon's Avatar
Pinky Demon
Pinky Demon is offline
No harm whatsoever. Can't tell you how many trucks the guys I work for have with leaking manifolds. Been driving them for years. They just keep going.
Old 06-30-2010, 09:40 PM
TennesseeMustangPerf's Avatar
TennesseeMustangPerf is offline
The only way that it can cause damage is if the truck sucks in enough cold air (air temp is below 80 degrees and the leak is large enough) that it warps the valve train. This can easily be done with open headers, but just a header leak it is doubtful. It can also cause the engine to overcorrect the condition by running rich, but again not enough that it will cause an immediate problem.
Old 06-30-2010, 09:45 PM
510guy's Avatar
510guy
510guy is offline
my 08 f350 5.4 just had its right side manifold replaced under warranty, had been leaking without causing any problems for a few months. the right side one on the boss' 150 had broken as well, but he just got a new truck instead...
Old 07-01-2010, 04:17 AM
redford's Avatar
redford
redford is offline
Received 1,549 Likes on 904 Posts
It may not be an exhaust leak. There are other things on the 3V 5.4L engine that will tick when cold but fade when the engine warms up, like the cam phasers, loose spark plugs, or cam followers with an inadequate oil supply . You need to have the noise source pinpointed before you can determine if it will be a bad thing to ignore it.
An exhaust leak could be bad for you.
I don't mean to insult anyone who might work at Midas but most of the time taking your truck to a local Midas dealer and taking your truck to a mechanic are two different things.
CharlieG
Modular V8 (4.6L, 5.4L)
12-29-2019 12:27 PM
F250 89
10-30-2017 03:54 AM
jpilk99
05-09-2017 10:29 PM
cedarkiller
1997 - 2003 F150
06-06-2011 08:39 AM
papajoemrt
1997 - 2003 F150
18
12-10-2009 11:20 PM
Quick Reply: Will my leaky manifold cause damage?
