FE rear sump (4X4) oil pan - Ford Truck Enthusiasts Forums
Old 02-08-2003, 03:54 PM
Chas1234 Chas1234 is offline
Chas1234 is starting off with a positive reputation.
Well I have looked here in the classifieds for an oil pan for my 360 and havent found anything...I looked at the milodon oil pans and really dont like the price...I tried looking for the one canton makes and could not find it . Does anyone have a part number ? Does anyone have a oem one they would like to sell along with the dipstick,tube and pickup . I currently have the 2wd version on my truck ...If anyone is interested or would like to trade that would be welcome too .....Thanks for any help in advance
Jon
Old 02-08-2003, 11:43 PM
Come on guys someone has to have a oil pan or a part number for the Canton?!
Jon
Old 02-10-2003, 02:03 AM
Well I guess the oil pans are in limited supply ..becides that I'm talking to myself LOL
Old 02-10-2003, 02:39 AM
Ratsmoker's Avatar
Ratsmoker Ratsmoker is offline
Ratsmoker is starting off with a positive reputation.
You can't find one in the junkyards? If I were still in OKC I could have about 5 of them in 3 hours. Might take only two junkyards to get that many.
Old 02-10-2003, 01:05 PM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
You can pull a used one off of a used car or truck for $5-$10 at a junk yard. It is a messy job, but, someone has to do it.
Usually the only reason someone would want to get rid of a functioning pan is either it was warped or bashed and it leaks.
I would look for a junk yard dog truck resting on blocks or rims (I would use jack stands though) with its front axle gone. That should be easy to find.
Old 02-10-2003, 01:08 PM
thats the problem up here in CT ..the engines that didnt run have been crushed and are long gone and the ones that are running are still in trucks...its snowing (again) so so I am not going to be running around the junk yards today or even this week !
the only good engines left in the yard are 351M/400 small blocks and 300L6s ...around here you get the " it runs good only 70,000 miles on it" untill you walk out and look at the "good running" engine that has no carb, dizzy and is full of water! ...there is one truck I havent asked about the pan ..he wants 700 for the truck '76 F250 4X4 360,(fullof water no dizzy or carb)np435 tranny but I dont need more junk in the yard and I'm not paying 700 for an oem oil pan.....hey if anyone has one with all the hardware I am more then willing to pay for shipping it doent matter where you are located ,I have some FE stuff comming to me from Alaska!
thanks
Jon
Old 02-10-2003, 10:07 PM
jbulson's Avatar
jbulson jbulson is offline
jbulson is starting off with a positive reputation.
I am about to junk an old rusted up 390 block after i take the crank out...ill save the pan if ya want it.
Old 02-10-2003, 10:09 PM
tejomakash tejomakash is offline
tejomakash is starting off with a positive reputation.
Chas1234, may I borrow your thread?
Ratsmoker,
You seem pretty familier with the OKC area boneyards, so, which ones should I hit when I start looking for good parts?
Good luck in Korea!
Chas, thanks for allowing my intrusion.
Old 02-11-2003, 02:05 PM
Jbulson: I would be interested in that pan if its a rear sump with a good dipstick and tube + the oil pump pickup tube...Let me know the details
Jon
Old 02-11-2003, 03:24 PM
Chas,
Check the classifieds here more. There was someone in either VA/GA parting out three or four FE engines/trucks.
Old 02-11-2003, 06:29 PM
ok I'll check again...I looked last night and didnt see anything by the way Thanks!
Jon
Old 02-11-2003, 06:35 PM
Ratsmoker's Avatar
As for the boneyards. There is pull - a- part on 15th and robinson with all kinds of old ford trucks in the FE era. There is a good place on westminister between SE29th and NW10th somewhere called barbers. This guy will try and charge you 80 bucks for a bolt but you can get him down to very reasonable prices. There is also a good place on eastern between 29th and 44th that called carey's AAA. There is a whole lotta cool stuff there. There are so many more but these were usually the places for me.
Old 02-11-2003, 06:40 PM
Thanks alot, Ratsmoker!
Old 02-11-2003, 07:39 PM
I wish we had yards like that around here Everything is generally over priced ....I dont think engines with water in them and parts missing are worth $600 bucks ....but thats the way it is up here..
Jon
Old 02-11-2003, 08:06 PM
Ratsmoker's Avatar
That kind of sucks man. Put a wanted ad in the classifieds too. It might get you something.. For may still sell the pan? I dunno. They still keep a few FE things around.
7.3L Oil Pan Replacement weeeves 1999 - 2003 7.3L Power Stroke Diesel 30 09-23-2016 02:07 PM
Oil pan questions andrew's64 1967 - 1972 F-100 & Larger F-Series Trucks 15 08-22-2016 12:17 AM
Oil pan gasket replacement 2000 f250 5.4 2wd madmedic8526 1999 to 2016 Super Duty 4 03-14-2016 03:40 PM
Derale Trans pan AZFX4 1994.5 - 1997 7.3L Power Stroke Diesel 8 01-06-2016 05:03 PM
FE rear sump oil pan dano1805 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 5 02-28-2015 05:17 PM
Tags
390, 4x4, dipstick, f250, fe, ford, oil, pan, pans, pick, pickup, rear, sump, truck, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
