1996 powerstroke common problems
Old 06-30-2010, 02:36 PM
southernboy0122's Avatar
southernboy0122
southernboy0122 is offline
Hey im looking at getting a 1996 f250 single cab 7.3psd with 186,000 miles on it. he wants 3300 for it. i was wondering whats the common problems with this motor are, and if its reliable and quick at the same time. is there any turbo lag, for work i drive an 08 f350 and the turbo lag on that is crazy bad, but once it gets spooled its quick. just wondering what you guys think of it? Thanks
1996 F250 Powerstroke turbo diesel 4x4 lifted
Old 06-30-2010, 02:45 PM
Talyn's Avatar
Talyn
Talyn is offline
Tips - Idea - Hints
Steve has great tips on picking out a truck.
I'd be sure to give it a look over in person and drive it before purchasing, but only wanting 3300 so he can get a new truck seems low.
Make sure to check the front for how he did the lift.
Make sure he dropped the hangers for the TTB, that is important.
Old 06-30-2010, 09:43 PM
rolltide3006's Avatar
rolltide3006
rolltide3006 is offline
mine is a 96' also. The guy I bought mine from was having to use ether to start it up. I bought it anyway. It got to the point where it wouldn't start up. I replaced the glow plugs thinking it was them. It still wouldn't start. I almost gave up on it then someone told me to check the HPOP res. It was bone dry. I filled it up and she's fired up ever since- no ether. I guess I got a new set of glow plugs out of it.
When it fires up see how much the smoke clears up after about 10 min. If it still has a lot of smoke in injector o-rings might be going- might be the rings though. Either my injector orings are going or my rings are, but I don't mind that much cause my truck runs strong. As far as turbo lag, I don't think the older 7.3s have this prob, but I'm not real sure about that- hopefully someone else will chime in. My turbo seems to be good all the way through the powerband and its stock.
Old 12-28-2010, 06:24 PM
arecycling77's Avatar
arecycling77
arecycling77 is offline
I have a 96 f350 the only problem I have had so far was a CPS. Easy fix even in the cold.
Old 12-28-2010, 07:11 PM
Scud Runner's Avatar
Scud Runner
Scud Runner is offline
Ok, what does HP0P and CPS mean?
Old 12-28-2010, 07:50 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
High Pressure Oil Pump
Cam Position Sensor
Old 12-29-2010, 05:34 AM
m50's Avatar
m50
m50 is offline
OK I guess I am a dummy just where is the HPOP resivoir? I have a 96 7.3 also and didn't know there was such a thing but my truck does not want to start real good and was wondering if this could be the problem.
Old 12-29-2010, 06:09 AM
427 fordman
in front of the motor, in middle, on top. It's got a sensor on the pass. side and a small plug on the drivers side, both on top. About 8 inches wide, couple inches deep.
Old 12-29-2010, 12:01 PM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
What do you put in the HPOP reservoir if it is low? Just curious, as I knew nothing of this.
Old 12-29-2010, 12:13 PM
Robbgt's Avatar
Robbgt
Robbgt is offline
Whatever oil you're using in the engine. That's what circulates through the HPOP.
Old 12-29-2010, 12:27 PM
DIYMechanic
Huh, good to know. Thanks for the info. I will have to check mine as well.
Old 11-14-2011, 08:12 PM
Jeffro strokin's Avatar
Jeffro strokin
Jeffro strokin is offline
Hey Guys i got a 96 powerstroke will hardley start when its warm thinking of changeing oinjectors but o rings a good place to start idles ok but spits smoke and runs rough at high rpm's . What to do? Tested glow plugs all good.
Old 11-14-2011, 09:16 PM
fordpride's Avatar
fordpride
fordpride is offline
Sound like IPR orings
fordpride's Avatar
fordpride
You may want to start a new thread
Old 11-15-2011, 02:36 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Ford4Life7.3 is offline
X2 on the IPR. Start a new thread, we'll get you sorted out
Quick Reply: 1996 powerstroke common problems
