1996 powerstroke common problems - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 06-30-2010, 03:36 PM
southernboy0122's Avatar
southernboy0122 southernboy0122 is offline
southernboy0122 is starting off with a positive reputation.
Hey im looking at getting a 1996 f250 single cab 7.3psd with 186,000 miles on it. he wants 3300 for it. i was wondering whats the common problems with this motor are, and if its reliable and quick at the same time. is there any turbo lag, for work i drive an 08 f350 and the turbo lag on that is crazy bad, but once it gets spooled its quick. just wondering what you guys think of it? Thanks
1996 F250 Powerstroke turbo diesel 4x4 lifted
Old 06-30-2010, 03:45 PM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Tips - Idea - Hints
Steve has great tips on picking out a truck.
I'd be sure to give it a look over in person and drive it before purchasing, but only wanting 3300 so he can get a new truck seems low.
Make sure to check the front for how he did the lift.
Make sure he dropped the hangers for the TTB, that is important.
Old 06-30-2010, 10:43 PM
rolltide3006 rolltide3006 is offline
rolltide3006 is starting off with a positive reputation.
mine is a 96' also. The guy I bought mine from was having to use ether to start it up. I bought it anyway. It got to the point where it wouldn't start up. I replaced the glow plugs thinking it was them. It still wouldn't start. I almost gave up on it then someone told me to check the HPOP res. It was bone dry. I filled it up and she's fired up ever since- no ether. I guess I got a new set of glow plugs out of it.
When it fires up see how much the smoke clears up after about 10 min. If it still has a lot of smoke in injector o-rings might be going- might be the rings though. Either my injector orings are going or my rings are, but I don't mind that much cause my truck runs strong. As far as turbo lag, I don't think the older 7.3s have this prob, but I'm not real sure about that- hopefully someone else will chime in. My turbo seems to be good all the way through the powerband and its stock.
Old 12-28-2010, 07:24 PM
arecycling77 arecycling77 is offline
arecycling77 is starting off with a positive reputation.
I have a 96 f350 the only problem I have had so far was a CPS. Easy fix even in the cold.
Old 12-28-2010, 08:11 PM
Scud Runner's Avatar
Scud Runner Scud Runner is offline
Scud Runner is starting off with a positive reputation.
Ok, what does HP0P and CPS mean?
Old 12-28-2010, 08:50 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
High Pressure Oil Pump
Cam Position Sensor
Old 12-29-2010, 06:34 AM
m50 m50 is offline
m50 is starting off with a positive reputation.
OK I guess I am a dummy just where is the HPOP resivoir? I have a 96 7.3 also and didn't know there was such a thing but my truck does not want to start real good and was wondering if this could be the problem.
Old 12-29-2010, 07:09 AM
in front of the motor, in middle, on top. It's got a sensor on the pass. side and a small plug on the drivers side, both on top. About 8 inches wide, couple inches deep.
Old 12-29-2010, 01:01 PM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
What do you put in the HPOP reservoir if it is low? Just curious, as I knew nothing of this.
Old 12-29-2010, 01:13 PM
Robbgt's Avatar
Robbgt Robbgt is offline
Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.
Quote:
Whatever oil you're using in the engine. That's what circulates through the HPOP.
Old 12-29-2010, 01:27 PM
Huh, good to know. Thanks for the info. I will have to check mine as well.
Old 11-14-2011, 09:12 PM
Jeffro strokin Jeffro strokin is offline
Jeffro strokin is starting off with a positive reputation.
Hey Guys i got a 96 powerstroke will hardley start when its warm thinking of changeing oinjectors but o rings a good place to start idles ok but spits smoke and runs rough at high rpm's . What to do? Tested glow plugs all good.
Old 11-14-2011, 10:16 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Sound like IPR orings
fordpride's Avatar
You may want to start a new thread
Old 11-15-2011, 03:36 PM
Ford4Life7.3's Avatar
Ford4Life7.3 Ford4Life7.3 is offline
Ford4Life7.3 has a good reputation on FTE.Ford4Life7.3 has a good reputation on FTE.Ford4Life7.3 has a good reputation on FTE.
X2 on the IPR. Start a new thread, we'll get you sorted out
P0299 code again Mark_in_co 6.0L Power Stroke Diesel 8 11-16-2016 09:58 PM
A lot of turbo lag after SCT canned tune//UPDATE 2006powerstroke90 6.0L Power Stroke Diesel 9 08-22-2014 12:01 PM
turbo lag? RRTREE 6.7L Power Stroke Diesel 3 08-17-2014 10:56 PM
2015 6.7 PSD - Turbo Lag / No-Lag Reports Big-Foot 6.7L Power Stroke Diesel 6 06-18-2014 07:55 AM
F250 Turbo Lag RD688 6.0L Power Stroke Diesel 10 09-03-2011 04:50 PM
Tags
1996, 1997, 73, 96, cab, common, diesel, f250, f350, ford, lifted, powerstroke, problems, single, turbocharger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
