Trans tunnel rot
Old 01-15-2016, 07:15 PM
Anthony Polsinelli's Avatar
Anthony Polsinelli
Anthony Polsinelli is offline
Trans tunnel rot
Hey guys, so I am going to be getting a 97 f250 single cab, the trans tunnel is rotted out around the 4wd shift on the floor. Im not sure the extent, but how complex are those tunnels? or is it something i could make easily out of some sheet metal? (I have an almost full sheet of like 14-16 gauge) If it is not that bad and its just a small section around where it enters than i will probably just cut a piece thatll fit right in. if it is bad though, can the whole thing be replaced or made?
Old 01-15-2016, 09:53 PM
stainlessstroker95's Avatar
stainlessstroker95
stainlessstroker95 is offline
Maybe you could go to a salvage yard and cut the section out you need.
Old 01-16-2016, 08:43 AM
Bob_T's Avatar
Bob_T
Bob_T is offline
A friend with one of those old Toyota Landcruisers repaired his rotten trans tunnel and floor using fiberglass cloth and polyester resin. It worked pretty good although, if it matters, it might not have the same resale value as a properly repaired steel repair. Polyester resin is pretty smelly and you can use epoxy resin instead.
Old 01-16-2016, 08:13 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
If it is rusted out that bad around the 4x4 shifter, then I would think the cab mounts and floor board over by the kick panel would be shot.
F-250 restorer
05-06-2018 08:03 PM
dano1805
03-09-2015 06:13 PM
dixie460
10-09-2012 11:07 AM
DHCowdude
06-19-2011 11:03 PM
78LongLariat
16
08-03-2009 12:19 AM
Quick Reply: Trans tunnel rot
