Question about changing factory radio radio. - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-30-2010, 11:44 AM
lacajun069 lacajun069 is offline
lacajun069 is starting off with a positive reputation.
I want to replace the factory CD changer in my 2003 f250 super duty with a 6L8t-18C815-AD from an 2005-2006 Escape. Is it possible to make this change? Can I buy the necassary adaptors? The head unit has the SAT/AUX buttons which I want to use for my Sirius Stiletto 2 radio.
My old radio that came with the truck has 6 disc stuck in it and I get the dreaded CD error. So I need to replace it and autopsy to get my son and my CD'S out of it.
Old 06-30-2010, 12:30 PM
b1er b1er is offline
b1er is starting off with a positive reputation.
from the reasearch i've done, the radio's are different... I've been researching iPod adapters for the wife's escape and the F250 and escape use a different one so I would "assume" since they use different iPod adapters that the wiring and plugs are different... I'll know for sure this weekend when I install the iPod adapter in the escape... I have my 6 disk from my F250 on a shelf so i'll compare them while the escape is apart and try to let you know... and if you need a new 6 disk, I'll make you a heck of a deal on mine...
Old 06-30-2010, 01:20 PM
TennesseeMustangPerf's Avatar
TennesseeMustangPerf TennesseeMustangPerf is offline
TennesseeMustangPerf has a good reputation on FTE.TennesseeMustangPerf has a good reputation on FTE.
What kind of a deal? If he isn't interested I might be. My 350 needs a new one, the changer keeps shuffling discs by itself. Obviously first dibs goes to the OP though. Thanks!
Old 06-30-2010, 04:02 PM
cool.... I'll wait to hear from the OP, if he doesn't want it then your welcome to it...
PM sent...
Old 06-30-2010, 10:20 PM
03powerstroke60 03powerstroke60 is offline
03powerstroke60 is starting off with a positive reputation.
If those don't take dibs then I would like a shot at it. I've got an 03 350 the the light hardly ever works on the radio, making it difficult to tell what channel that I have it on.
Old 06-30-2010, 10:57 PM
joetech joetech is offline
joetech is starting off with a positive reputation.
I think that is the one I used in my 04 I got an adapter online to hook up an xm and used the radio to control it
Old 07-01-2010, 01:21 AM
2002 F350V10 2002 F350V10 is offline
2002 F350V10 is gaining momentum as a positive member of FTE.
Try this for the stuck cds in the radio. I was able to get them out, and the cd unit reset itself upon powering up. Remove the radio and put it on a workbench or the kitchen table. To get it apart, the front face needs to come off. I believe its a couple screws on each side, and the front face will come off and 1 wire plug to unplug. then looking from the front, gently slide the cd or cds out. Put the face back on, and reinstall in the truck. when powering up after plugging in the plugs , mine reset itself and now works again.
Old 07-01-2010, 07:41 AM
scottzj's Avatar
scottzj scottzj is offline
Hangin 10 bra
scottzj has much to be proud ofscottzj has much to be proud ofscottzj has much to be proud ofscottzj has much to be proud ofscottzj has much to be proud ofscottzj has much to be proud ofscottzj has much to be proud ofscottzj has much to be proud ofscottzj has much to be proud ofscottzj has much to be proud of
A good deal of Ford vehicles use the same radio. I had a guy buy my 6 disc changer for his wifes Ford SUV and it bolted up nicely. However, you have to make sure the plugs are the same as the model you will swap with.
Old 07-01-2010, 08:11 AM
frozenpoet frozenpoet is offline
frozenpoet is starting off with a positive reputation.
Why waste your money on facto crap when you can put a nicer aftermarket one in for not a lot of coin? My 250 just had the radio and for 60 bucks for the new head unit, wire harness, and dash kit I have a better then stock setup. The new head unit is nothing fancy but it has the aux input that I wanted, didn't even noticed till after I bout it that it didn't play cd's lol. There are two different wire harnesses though, one is a short fat one and the other is two harnesses. (one for power, the other for speakers) so watch out for that. Also you should be able to switch out the harness without too much trouble, not the easy way to do it but it's doable.
Old 07-01-2010, 10:06 AM
TXHillCountry's Avatar
TXHillCountry TXHillCountry is offline
TXHillCountry is starting off with a positive reputation.
Quote:
Originally Posted by frozenpoet View Post
Why waste your money on facto crap when you can put a nicer aftermarket one in for not a lot of coin? .
I'll second that. I wanted an external AUX input (standard 1/8th inch jack) for my XM radio. I have the exact same setup as the OP, on my 2003.
I eventually just purchased a good aftermarket radio from Crutchfield that came with all the mounting hardware and wiring adapters to make the installation "plug and play". And now I have a radio that has Bluetooth, HD Radio, Aux, Ipod control, etc, for a fraction of a factory setup.
TX
Old 07-01-2010, 10:21 AM
I just got through fighting this battle with the wife's vette... it had a crummy stock NAV reciever with no iPod input... it was a pain in the a$$ to install the iPod controller and then have it only half work, no song data, no direct track access, no video or album art... dumped all that stock crap and put a Kenwood DVD/NAV(DNX-5140) head unit in... man what a difference... it was pricey(800.00) but in the end, with all the options and accessories I have now, I can hook up or play just about any file from any device made... and she's ecstatic... and thats always good...
Old 07-01-2010, 12:30 PM
I should have also posted for the original poster that I have my original radio, the same as he has, if he wants to replace it.
It also has the PIE Ford AUX adapter that plugs into the remote CD Changer port (unused on these F-series installs) that provides a standard AUX input. I just plugged an 1/8th inch audio cable into it and ran it out from under the dash for easy access to plug in things like Sirius/XM radios, MP3 /iPod players, etc.
My primary reason for upgrading to a new radio was that I wanted something that supported a subwoofer, which I've installed under the rear seat.
TX
Old 07-01-2010, 01:14 PM
brian42's Avatar
brian42 brian42 is online now
brian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to behold
Yes, the radio will fit. You will have to buy (or make) an adapter because the plugs are different. OEM Car Radios. Factory stereo repair. Car radio parts and accessories. make a pigtail adapter. The physical unit is a direct replacement.
I went OEM so that I don't attract would-be thieves thinking that my truck is worth breaking into or stealing because I'm packing some $$$ inside the cab. Not to mention that I'm old and don't need dancing lights, displays or iPod connections. I have higher power, MP3 capability, an OEM look and it doesn't take up any extra room than the previous unit.
I could have gotten a pretty good Alpine for the same price or a little more, but then I would have to get an installation kit and take the time to install it. With my Escape radio, I have an in-dash 6CD changer and higher power (Audiophile unit) and all I had to do was take the old one out, connect an adapter cable and slide the new one in.
Radio Changes Stations During Braking Big Sky Excursion - King of SUVs 0 08-19-2016 12:07 PM
Radio interchangeability am/fm/cd - am/fm/6disc cd cmorningstar01 2004 - 2008 F150 7 06-02-2015 06:41 AM
2003 F250 Radio Swap StangPullerF250 1999 to 2016 Super Duty 2 12-19-2010 08:09 PM
6 disc/radio problem pennyv 2009 - 2014 F150 5 10-30-2009 08:44 PM
Anyone have factory radio/CD player they want to sell Dads79 Excursion - King of SUVs 11 01-03-2009 06:51 AM
Tags
2010, 6l8t18c815ad, alpine, bluetooth, changing, edge, f150, f250, ford, head, oem, radio, replacing, stock, truck, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
