460 life span - Ford Truck Enthusiasts Forums
460 life span
Old 06-30-2010, 11:44 AM
2005 Harley Stroke 2005 Harley Stroke is offline
2005 Harley Stroke is starting off with a positive reputation.
460 life span
Hey all, my Dad is looking at buying a '94 F250 with a camper... How many miles will a 460 take before it is shot? I think of the old big blocks and 100,000 seemed like there on the edge of death. I could be wrong though. Here is a link to the add so you know as much about it as I do.
ksl.com - Classifieds for Utah, Idaho, and Wyoming=
He is really interested in the camper, but the truck is only 2.5K. Would he be better off with a newer truck and the V10? I just don't want my Dad to end up needing an engine in the near future. Thanks in advance.
Old 06-30-2010, 04:03 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
There is no inherent design problems in the 7.5L engine. If the previous owners kept up on maintenance there is no reason a modern engine would not go 200K+ miles before needing major service.
Old 06-30-2010, 04:14 PM
capn kirk capn kirk is offline
capn kirk is gaining momentum as a positive member of FTE.
im almost at 200k its my work truck im planning on replacing it after i put another 100k through it. Really with regular maintenance nothing really goes wrong with em
Old 06-30-2010, 04:15 PM
mfbbwood's Avatar
mfbbwood mfbbwood is offline
mfbbwood is starting off with a positive reputation.
I have a 95 with 160,000 on it and other than a trans (all my fault) I havent had any major problems.
Old 06-30-2010, 05:46 PM
Old93junk's Avatar
Old93junk Old93junk is offline
Old93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputation
If properly maintained and driven by a adult.................forever
I know of a guy at work with a 390,000 mile 460 in his 91 F-250, never been opened up, uses 1/2 qt of oil in 3,000 miles.
Old 06-30-2010, 06:37 PM
StealthWyvern StealthWyvern is offline
StealthWyvern is starting off with a positive reputation.
it really depends on what RPM range the engine was in majority of its life... low and babied the frame might rust out before it goes.... High strung motors tend not to last as long as low strung motors. off topic - I personally think this is why diesels last so damn long but that may be just me.
Old 06-30-2010, 11:15 PM
ArdWrknTrk ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
My carbureted '87 made it to almost 315k before it finally spun a bearing on cold startup.
It was losing about a quart in 3000 miles at that point.
The engine itself is very sturdy, which made it a favorite among fleet departments and bus companies.
Old 07-01-2010, 12:46 AM
Molineguy Molineguy is offline
Molineguy is starting off with a positive reputation.
I agree with the other guys, it should run for a long time yet. Dad has around 170,000 on his 89 250 4wd with 460 and 5 speed and uses a quart or two between 3000 mile oil changes, depends if its pulling trailers or just getting through the snow. His 92, and 94 F150's with the 302 each have around 170,000 and seem to run well and use little oil also.
Looks like a nice truck, probably worth the money.
Old 07-01-2010, 12:51 AM
70torino429's Avatar
70torino429 70torino429 is offline
70torino429 is starting off with a positive reputation.
100k isn't much for any of the engines ford put in the trucks. Even with not-so-great treatment, 150k is easy. With good maintenance, 200k and beyond isn't unheard of. I'd say go for it if the price is within your budget.
Old 07-01-2010, 02:04 AM
Elderstarr's Avatar
Elderstarr Elderstarr is offline
Elderstarr is gaining momentum as a positive member of FTE.
My truck had 400,000 km on the clock before I ripped out the 460 and installed a 351w. Sold it to a guy for a drag car project, lasted 4 months before bearings went but had the bottom end rebuilt. They are very durable motors if you take good care of them.
Old 07-01-2010, 07:12 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Quote:
I hope you are wrong.
I run my 1994 460 at a very high RPM on any hill at 35 MPH with a 5.13 rear end and it has 57,000 miles on the clock but I was told the PO had already changed the engine because of an oil leak and it now has 10,000 miles on the engine. It also runs very hot at the high RPM with the electric fan and stock fans both running.
I have not come up with a way to change the engine yet, they tell me it has to come out the bottom. So I am think about building a pit to take it out when it comes time.
To the OP that looks like a good deal, if I did not already have two RV's (class A and a class B) and a van made for camping I would go for it and put out with my other eleven Fords. Ford makes good engines and the 460 is one of the best. But if he buys it and is going to pull something have him install a track bar on the rear end to keep it from tail waging.
Old 07-01-2010, 07:59 AM
150ford 150ford is offline
150ford is gaining momentum as a positive member of FTE.150ford is gaining momentum as a positive member of FTE.
The 460 is excellent for durability an longevity. Can you really ever wear them out? I have 1 460 that is over 21 years old used an indusriall application thats got over 15,000 hrs on the clock and is running as good as it did when it was new. Thats a lot off miles. I have always said the two best motor Ford ever put in to a pickup were the 460 an 390. I know a neighbor off mine has a 390 in an old 72 that refuses to die. He bought the truck new an it is running great yet. But its a Ford and you expect that. If you look at the truck pulling circuit. Those motors are popular because they can take all the abuse they dish out.
Old 07-01-2010, 11:32 AM
Quote:
Originally Posted by subford View Post
I
Why would it have to come out the bottom ? That makes no sense in these trucks. That's a FWD phenomenon.
Old 07-01-2010, 01:53 PM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
Its probably a motorhome....Lew
Old 07-01-2010, 02:30 PM
subford's Avatar
Quote:
Because I can not take it out the front or top.
This is on the F53 in my signature.
I thought about pulling it up through the top and then taking it out through the side window but I do not know if it will fit through the side window or through the top hole. I would have to put down 3/4 plywood for the engine hoist to move around on while it is inside. I would not want to take it out through the windshield because there is a center divider in the windshield.
First Truck! Need some expert advice! agnumba1 1967 - 1972 F-100 & Larger F-Series Trucks 11 02-20-2015 04:06 PM
'51 F5 Boom Truck fbb1951 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 09-03-2014 10:46 AM
Dent Side Eye Candy, Also For Sale Daveyj 1973 - 1979 F-100 & Larger F-Series Trucks 8 12-20-2011 11:47 AM
OT Nash Truck ??? jmadsen 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 09-03-2011 08:26 PM
Tags
1978, 400000, 460, 68, average, engine, engines, ford, gas, life, lifespan, milage, miles, motorhome, span
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
