460 swap with 400 bell housing clutch problem
Old 07-14-2014, 07:59 PM
bmorey's Avatar
bmorey
bmorey is offline
460 swap
My clutch kit came in today. The flywheel won't be here for a few days. I am hoping the flywheel makes the difference, because the clutch hub is the same as before.
  #32
Old 09-12-2014, 08:24 PM
bmorey's Avatar
bmorey
bmorey is offline
I finally got all of this together. To recap:
460 engine, 360 flywheel and clutch, cast iron bell housing. Now here is the weird part. When I tried to bolt up the four speed transmission the input shaft sleeve bottomed out on the clutch hub. I went to the salvage yard and found a '74 two wheel drive and bought the transmission for a spare because the truck wasn't going to be there much longer. on a lark, I took the sleeve off of that transmission and it was .125" shorter than mine. I swapped those out and everything bolts up fine.
go figure.
4x484150
13
12-17-2016 06:53 PM
82fordowner
16
06-23-2016 03:15 PM
Landspeed F100
Engine Swaps
12-04-2015 07:41 PM
PintoGuy
17
06-22-2015 08:58 PM
greyhound
1961 - 1963 F100 Unibody
04-19-2015 08:25 PM
Quick Reply: 460 swap with 400 bell housing clutch problem
