1994.5 7.3 and cruising rpms - Ford Truck Enthusiasts Forums
Old 06-30-2010, 01:13 AM
Coccyx Coccyx is offline
Coccyx is starting off with a positive reputation.
Hi everyone,
brand new to the forum, but I've browsed lots before. Just retired my 1990 f250 with the 7.3 non-turbo diesel, and bought a 1994.5 f250 4X4 with the turbo diesel.
Axle code is 35, which I think means 4:10 gear ratio rear end. Trans. is 5-speed manual. Tires are wider than the stock recommended size, but are the same diameter (I measured). shouldn't affect speedometer/engine speed ratio, anyway, just ground speed.
Cruising RPMs at 100 km/hour (what's that, about 62 MPH?) in overdrive is close to 2500 RPM. To me, this seems high for a big turbo diesel. I was expecting it closer to 2000... maybe 2200 tops.
Do these numbers match what's expected for 4:10 gear ratio? Or did someone put a slow rear end in there at some point (there's been a few owners). I may think about gearing it higher, but I need to know where I'm starting from first!
Thanks very much and thanks also for keeping up this forum. I learn tons every time I visit.
Scott
Old 06-30-2010, 01:35 AM
mongo12 mongo12 is offline
mongo12 is starting off with a positive reputation.
your gear ratio should have the engine spinning around 2093 (give or take a few). sounds like someone might have put lower gears in the rear. i used novak conversion's calculator and it looks like you might have close to a 5:1 gear ratio.
Old 06-30-2010, 06:20 AM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
Brown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud of
Sounds about normal for 4.10 gears.
I had 4.10's before and at 65 it was close to 2500rpm with 235/85-16's
I have 3.55 gears now and run just over 2100 at 65 now, with 285/75-16's
Old 06-30-2010, 10:22 AM
Paladin921 Paladin921 is offline
Paladin921 is starting off with a positive reputation.
Sound right for 4.10's. Mine came that way but switched it out to 3.55 and I cruise at 1900rpm @ 75mph with an E4OD in overdrive.
Old 06-30-2010, 12:35 PM
redman84's Avatar
redman84 redman84 is offline
redman84 has a good reputation on FTE.redman84 has a good reputation on FTE.
I have 4.10s with a 5 speed and cruise at 70mph @ 23-2400 rpms. There was a thread on this the other day and many guys are the same. I'm at 2600 @ 75 and 2100 @ 65. These are estimated rpms but should be close. When I had the E4OD in they were a couple hundred or so lower in OD.
Old 06-30-2010, 01:04 PM
glasseater glasseater is offline
glasseater is starting off with a positive reputation.
my 4.10s and E4OD have me at just around 2000 rpms at 60mph (33" tires)
Old 06-30-2010, 02:34 PM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
I drive at 65 a lot, and its around 2200 RPM's with the same setup as the OP.
E4od has a taller overdrive than the 5 speed.
I have 33's for tires though also. Not sure if my speedo was calibrated. Last I checked it was still off.
Here is an easy way to figure out your rear end ratio.
Jack up the rear of the truck. (if you have an open diff, I think you have to leave one tire on the ground.)
Be sure to block the front tires, and put the truck in neutral.
Put a mark on the tire, and a mark on the driveshaft.
Spin the tire slowly, and count the amount of times the drive shaft mark goes around.
So, if you do have 5's in there, it will spin 5 times, and 4 times for 4, and with 3.55's it should be on the opposite side of the clock from where you made the mark originally.
Last edited by Talyn; 06-30-2010 at 02:35 PM. Reason: i'ma get this sentence right one of these edits.
Old 06-30-2010, 06:01 PM
Brutl_Force's Avatar
Brutl_Force Brutl_Force is offline
Brutl_Force is starting off with a positive reputation.
Holy crap. I had no idea people spin diesel engines so fast!!! I got my first powerstoke not long ago, and I have a cow it spinning 1900 going 55mph. I guess I am used to big trucks, with 1800 ceiling rpm. When the thing shifts at 2400, i always cringe.
While on topic, kind of, do all of these truck tuners that adjust shift RPM just adjust for full throttle shift points, or do they lower part throttle shift points as well, also I would like the ability to lock out the downshift from over drive to 4th (E4OD) over 45 MPH (I tow a lot), unless I manually (shift lever button) call for a downshift. Is this possible??
Old 06-30-2010, 06:16 PM
Talyn's Avatar
Yea. Look at where the redline is on our trucks.
Cring when you see a dodge or a chevy hitting 2600 trying to keep up with us. =)
Old 06-30-2010, 06:20 PM
Well, I consider red line to be never approached. Low end torque is what a diesel is for. But I grew up with tractors, and driving semi trucks. First V-8 diesel. Never will like revving them out. Still interested in adjusting shift points.
Old 06-30-2010, 06:30 PM
Talyn's Avatar
3 grand is about the normal high end of the rpm band for our trucks. You can go over it, but its not necessary.
I rarely shift over 3 grand.
You don't start making any power till around 1800 rpms.
Old 06-30-2010, 06:42 PM
Doesn't that kind of engine speed dramatically reduce the life of these engines?, gotta be hard on it.
Old 06-30-2010, 07:04 PM
Quote:
not really, there are several cases of 1,000,000+ 7.3s
and don't worry about the rpms, better to have lots of rpms and high hp then no rpm and lots of torque... torque doesn't do anything except add hp at the bottom of your rpm band, get out of the torque thinking
Old 06-30-2010, 07:56 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
torque is applied pressure.the force power.
this is everything when it comes to moving a load.
this is why diesels outperform their gas equivalent when it comes time for work, because diesels have so much torque or "grunt" if you will.
think of HP as your momentum to keep the load moving,but its not the "force" / "grunt" that moves the load,thats the torque.when it comes to a "work" truck.torque means everything.HP keeps it moving along down the road.
Old 06-30-2010, 09:51 PM
plgebbia's Avatar
plgebbia plgebbia is offline
plgebbia has a good reputation on FTE.plgebbia has a good reputation on FTE.
Hey, Brutl_Force
When your pulling with these trucks you dont want to lug a load up hill at 1500 rpm. that will sky rocket EGT even on a stock truck. I'm not saying to redline it, just don't lug it. these trucks are most efficient between 1800-2400 rpm. this is where you get the most bang for your buck power and efficiency wise. I do know what you are talking about though about excessive downshifting !! that's why I went to the 5 speed manual.
7.3 SD swap into a 1994.5 OBS bubba_3711 1994.5 - 1997 7.3L Power Stroke Diesel 27 02-17-2016 08:56 AM
From Chevy to Ford Brian Garrett New Member Introductions 4 02-24-2015 02:43 PM
dana 80 ratio's? da man Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 27 12-08-2014 11:46 AM
Fuel Control Manifold sejones585 1987 - 1996 F150 & Larger F-Series Trucks 0 12-03-2014 08:43 AM
Power Band Old90Uhaul Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 25 11-01-2013 10:30 AM
Tags
1994, 19945, 73, diesel, difference, direct, f250, ford, idi, injection, mods, performance, rpms, standard, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
