Finally got my pyro hooked up: temps.
I just got my pyro hooked up and here are a few avg. temperatures, cruising at 65 (2200rpm) 600 degrees, pedal on the floor in 5th gear from 60-75 I almost hit 1000 degrees. At Idle its about 275 degrees. I've got to go to Dallas to get a project truck next week so I'll see what the temps are towing, I'll be towing about 9,000lbs.
I wish I had numbers to compare with.
But An intercooler stops EGT spikes more than just keeps EGT's low.
If you dont have an intercooler, you'll notice when you get on the throttle, they shoot right up. The IC helps keep that from happening, and makes it go a bit more gradual.
Now, thats not its only purpose, because it does cool intake air either way, but from what I've read, it's more noticeable to stop EGT spikes.
Anyone have some before and after numbers for their IC install for just road cruising?
Yup but it wouldn't be as bad with smaller injectors than what I have.
The thing is, I can now drive my truck how I want to. I just have to be my own double check. It will pull 15,000 lbs straight up a hill if I want it to at 80 mph but I have to watch my temps so I choose to back off a bit.
50 - 100 Doesn't seem like much to me. The EGT spike I think would be worth it for me given the high elevation I'm at
