Track bar "ball joint" 05-07 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-29-2010, 10:04 PM
06silvercrew's Avatar
06silvercrew 06silvercrew is offline
06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.
Has anyone had to replace the track bar ball joint thats pressed into the axle housing recently? I am needing an old one for a project I am working on and dont want to buy a new one just to take some measurments. I would glady pay someone shipping plus a few bucks for the time to ship it.
Old 06-29-2010, 11:54 PM
wizardsr's Avatar
wizardsr wizardsr is offline
wizardsr is gaining momentum as a positive member of FTE.wizardsr is gaining momentum as a positive member of FTE.
Quote:
I just did both of them on my 05, I'll have to dig through the scrap metal pile to see if I can find them. Stay tuned...
Old 06-30-2010, 10:07 PM
Both? There is only one. Thanks for the reply!!
Old 07-05-2010, 06:45 PM
wizardsr's Avatar
I thought you were referring to the big bar right down in front that connects the 2 sides. Haven't had to replace the one from the pitman arm to the one side yet. I found them, they're laying on the floor of my truck, I'll snap a picture the next time I'm out there. Sorry for the delay, I've been swamped doing storm cleanup.
Old 07-05-2010, 07:37 PM
Yeah the bar that centers the axle under the truck side to side. Got a ball joint on one end and just a normal bushing on the frame end. But anyhow, I just ordered a new one from rock auto for $77 but I greatly appreciate you takin the time for me!
Old 07-06-2010, 10:06 PM
TxFireman1972's Avatar
TxFireman1972 TxFireman1972 is offline
TxFireman1972 is starting off with a positive reputation.
Not sure what you are working on but Carli has a new adjustable trackbar out:
Ford Super Duty Adjustable Track Bar, Pan Rod Bar
Old 01-17-2011, 07:08 PM
audkay audkay is offline
audkay is starting off with a positive reputation.
How hard was it to change, ford quoted me $372.00 parts and labor to do it, we would like to do it ourself.
Old 01-17-2011, 08:29 PM
Super easy if you have a ball joint press and the adapters. Once the bar is removed you will need to cut the tapered part off with a die grinder or similar the press it right out, and press the new one right in.
Here is a pic of it flipped opposite from its original position
Old 02-13-2011, 01:39 PM
wastedinsc wastedinsc is offline
wastedinsc is starting off with a positive reputation.
I have to replace my track bar ball joint do you happen to have the replacement part #. I have the ford part# but want to use a moog. I have searched everywhere but can't find anything that states it's a replacement for stock part #......... Any help would be appreciated. Thanks. I have an 05 F350 superduty Dually
Old 02-13-2011, 04:20 PM
No sorry, the replacement part I got from rockauto was a ford, but it had a grease fitting on it, the original did not. I was unable to find anyone taht offers this other then ford. IIRC it was about $60ish
Old 02-13-2011, 05:35 PM
OK, thanks
Old 06-25-2011, 07:20 PM
helirich helirich is offline
helirich is starting off with a positive reputation.
Silvercrew, I know this is an old thred, if your still around, could you please tell me about the tracbar in your picture with the balljoint flipped.
Also, does the stock ball joint press out up? (I assume) The reason you cut the taper was to fit in the balljoint press?
Old 07-04-2011, 12:18 PM
I got the ball joint pressed out. (without damageing it) I'm making an adjustable trac bar. I'm still hoping Silvercrew will see this and give the low down on the flipped trac bar. I'm going to have to get a tapperd reamer and ream the other side of the trac bar. I dont like that because of the hourglass taper it will create.
Old 12-17-2011, 02:23 AM
dazdillenger dazdillenger is offline
dazdillenger is starting off with a positive reputation.
I know this is an old thread I'm resurrecting, but I may be able to help. It irks me when people never post conclusions to these things. Here is my thread on the subject, I hope it helps Helirich.
2005 f350-adjustable track bar? Balljoint already flipped! Pictures? - Page 4 - Ford Powerstroke Diesel Forum
Old 12-17-2011, 08:20 AM
I'm not sure what irks you about this thread. In post #8, he posted what he did, with pictures. What more were you looking for?
Track bar ball joint flip jlmotox 1999 to 2016 Super Duty 5 08-07-2016 03:22 PM
Track Bar Ball joint R/I kidoo 6.0L Power Stroke Diesel 29 02-04-2014 08:18 AM
changing front track bar, problems MC5C 6.0L Power Stroke Diesel 0 12-19-2012 04:43 PM
Track bar joint? schmidt64 1999 to 2016 Super Duty 2 06-20-2012 04:23 PM
2005 stock f250 track bar tractorman41 1999 to 2016 Super Duty 4 02-11-2009 02:47 PM
Tags
05, 07, 2005, ball, bar, barball, bushings, duty, f250, ford, front, joint, removal, super, superduty, track, trackbar, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
