Brake and ABS Dash lights are on
Old 12-22-2014, 11:03 PM
madpogue's Avatar
madpogue
madpogue is offline
Originally Posted by ProjectDually
Will the rear drums being out of adjustment cause the same problem as well?
No. Think about the difference between disc and drum brakes. Disc brakes adjust for wear by moving the caliper piston out a miniscule amount with each bit of wear. Drum brakes adjust for wear with the mechanical adjuster that physically moves the shoes; the wheel cylinder isn't involved. So drum brake wear has no impact on the hydraulic fluid level.
Old 12-22-2014, 11:18 PM
ProjectDually's Avatar
ProjectDually
ProjectDually is offline
Thanks for that! I wasn't sure if there was hydraulic actuation there or not. I haven't torn into mine, and I have limited experience with drums.
I know on my car though, the clutch, and brake hydraulic fluid are all ran from the same master cylinder pump. It's one crazy octopus looking deal!
Old 12-23-2014, 12:29 AM
madpogue's Avatar
madpogue
madpogue is offline
The rear brakes are hydraulically ACTUATED (like any modern vehicle with drum brakes), but they're mechanically ADJUSTED.
There's no way one master cylinder can operate a brake system and clutch separately. They may share one reservoir, but there have to be two separate masters.
Old 12-23-2014, 04:37 AM
ProjectDually
I was reading up on what I said, they share the same reservoir. It's the master for the clutch, but the reservoir for the ABS pump. IDK. Without being able to look at car, it's hard to tell if I got that backwards or not.
Jaaaaaaackman
12-27-2016 12:34 PM
ReBilld
38
07-16-2015 06:16 PM
RIKIL
25
10-23-2014 07:40 AM
rustypierce
02-22-2014 06:48 AM
mikulskn
1997-2006 Expedition & Navigator
06-26-2013 11:23 PM
Quick Reply: Brake and ABS Dash lights are on
