Misfire in cylinders 3 and 4 ?????? - Ford Truck Enthusiasts Forums
Old 06-29-2010, 04:02 PM
J_Moore_21655 J_Moore_21655 is offline
J_Moore_21655 is starting off with a positive reputation.
Exclamation Misfire in cylinders 3 and 4 ??????
I bought gas at a station that now looking back may not have been the best place to buy gas, and ever since have had a miss in cylinders 3 and 4 and the truck runs really crappy. I've since added gas from another station after running all the gas from other crappy station and the problem persists. I've checked the plugs, wires and everything i could think of to be the culprit and no such luck. I'm at a loss ???????
Old 06-29-2010, 04:05 PM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
How did you determine which cylinders are misfiring? Also it would be helpful if you would tell us what kind of truck you have and what engine is in it?
Old 06-29-2010, 06:16 PM
Sorry about that I know, It's a 1995 F150 4.9L I6. I used the tried and true method of removing a plug wire at a time. Whatever cylinders are not firing will have no effect when the plug wire is removed. I determined that 3 and 4 are not firing due to the engine sound of running on four cylinders instead of six and that the removal of the plug wires from the 3rd and fourth cylinders had no effect on the runability.
Old 06-29-2010, 06:38 PM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
You already checked wires & plugs , you can switch them to a different clylinder to make sure , check your compression next ....Lew
Old 06-29-2010, 06:44 PM
Unhappy
I switched wires around and it's still missing on 3 and 4. I'm thinking it's a fuel issue and that's what i'm dreading. I'm gonna run a compression test next and see if anythings wrong there.
Old 06-29-2010, 07:01 PM
lew52's Avatar
Well better a fuel problem than a comp problem , let us know the results of the comp check ...
Old 06-29-2010, 07:24 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
Yea a compression test is a good idea but first I'd swap injectors around, swap injectors from known working cylinders over to the cylinders you know are not contributing.
If it the miss follows the injector/s I'd buy it a fresh set, if not I'd give the harness a good going over verifying the injectors do in fact all pulse. And of course the compression test, exact order done depending on how ambitious I was at the time!
That and I'd rather believe it was a fuel/injector/spark or harness issue of some kind rather then one or two suddenly toasted cylinders......
Old 06-30-2010, 06:18 PM
Unhappy
Well, I talked to some other people and they said that the gas station has sold them bad gas, so that's where i'm at now. the truck has 223,000 miles and I've changed the oil and done the other maintenance at the recomended intervals and I've had the truck since new give or take a few years. I didn't think it was a sudden drop of two cylinders either so I haven't run the comp. test yet, I I ran a KOER test on it and came up with the following codes
173 EGO Not switching
213 Spout circuit open
411 RPM Otu of specification, Normal Curb Idle
That was with a Snap-on scanner.
The spout is plugged in so I don't understand why it's saying it's open, I even ran a jumper in it's place (which is all the spout is) and it still said open circuit. I'm thinking one or more of the following:
Bad injectors
Bad EEC module
Bad O2 sensor
Any, some or all could be bad.
Sorry it's so long, just trying to give you all as much info as possible.
P.S. tested the injectors with a noid probe and the cylinders in question have a pulse. Doesn't necessarily mean they are getting proper fuel mix tho.
Old 06-30-2010, 06:32 PM
lew52's Avatar
Well you can switch the injectors around like danr said , & check compression , that will elimanate a few things , with 223.000 miles it could be anything , but when you have a dead miss on cylinders next to one another im thinking head gasket for starters....Lew
Old 06-30-2010, 06:46 PM
Thanks lew, I'm gonna run the comp. test as well as check some other things tomorrow. I was kinda thinking that as well, it's not burning coolant or running hot, but if it is the head gasket it could just be leaking into each other, right?
Yea I think I'd start with a compression test knowing that, even with a life time of proper maintenance that's kinda high.
Eliminate that as a possible problem and move on from there.
Old 06-30-2010, 06:49 PM
Quote:
Yea if all other cylinders are at a normal range but two adjacent cylinders share the same low reading its a pretty safe bet its the gasket between the two.
Old 06-30-2010, 06:54 PM
Okay, cool. I'm hoping it's not a head gasket only cuz I don't have the time to fix it. I know the compression should be around 180psi (a little lower due to mileage) if I'm not mistaken.
Old 07-28-2010, 06:29 PM
Cool
I started smelling anti-freeze in the exhaust two weeks back, and did the compression test and cylinders 3 and 4 were at 25 and the rest were at 150 so head gasket is bad.
Bought everything to do head gasket.
While doing the repair, took off the valve cover and found the intake pushrods for cylinders 3 and 4 were bent!!! WTF!!!!!!!
So now I'm worried as to what has caused this and what kind of damage has been done.
Old 07-28-2010, 06:57 PM
lew52's Avatar
When you pull the heads off you will find out , have a good look at the valves
Gotta drop the fuel tank :( Apocalypse Excursion - King of SUVs 11 02-24-2014 06:31 PM
Rant: what is the deal with some gas stations.. wagner78 General Diesel Discussion 5 12-10-2013 10:37 PM
Soot count kper05 6.7L Power Stroke Diesel 48 09-01-2012 09:14 PM
Need some help. 400 miles from home PADoubleX Excursion - King of SUVs 8 09-28-2010 11:51 AM
cant fill up tank InboundFX4 2004 - 2008 F150 15 03-21-2004 06:56 PM
Tags
09, 2006, 23l, 3, 49l, 91, and4, cylinder, cylinders, f150, f250, firing, ford, make, misfire, missfire, taurus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
