73 F700 vin decode
#106
1993 F-700
Could you decode mine? Vin# 1FDNF77J7PVA03353 Thanks. I an looking for a speedometer cable and transfer case linkage parts.
#107
B = Caterpillar V190 3208 8 cylinder diesel or (1978) Cummins KT40 6 cylinder diesel.
V = Kentucky Truck Assembly Plant.
CA8358 = 1978.
C55 = C550 Tilt Cab.
C = 330 2V Medium Duty FT engine.
A71534 = 1976.
#108
1990 F700 Crew Cab VIN breakdown
1FDXK74A8LVA13862
1990 F 700
Has dump box on it now.
Let me know what you can tell me on this.
Heard about it from a friend.
New to FTE!
1990 F 700
New to FTE!
#109
#113
92 F700 VIN
I know this thread is old but how would a guy go about decoding a vin on a 92 F700 vin: 1FDNK72P6NVA27258
any help would be appreciated...
#114
I know this thread is old but how would a guy go about decoding a vin on a 92 F700 VIN: 1FDNK72P6NVA27258
N = Class 6 - Hydraulic Brakes - 19,501-26,000 lbs. Gross Vehicle Weight Rating.
K72 = F700 Diesel.
P = 6.6L Ford Turbo Diesel.
6 = Check digit, FoMoCo use only.
N = 1992.
A27258 = 1992 Numerical Sequence of Assembly, the trucks specific serial number.
#118
#119
GVW stamped on the 3rd line, far left (see pic below).
Safety Standard Certification Label glued to the B pillar below the striker plate, has front/rear GVWR's printed on it. But, if it got wet, it could peel off.
martiauto.com has ALL the original 1967/79 FoMoCo records, but charges for any info.
Passing along your VIN will get a copy of the original build sheet, can also supply a new Warranty Plate with all the correct info on it, ditto for the Certification Label.
F70 = F700 (gas).
C = 429 4V (7.0L).
EE9098 = 1979.
Pic: Parts catalog example of the 1973/79 Warranty Plate.
