73 F700 vin decode - Page 6 - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
73 F700 vin decode
  #76
Old 10-03-2013, 01:38 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by RedStroke View Post
W.B. 146 / COLOR: A / MODEL: F611 / BODY: DB8 / TRANS: A / AXLE: F33 / MAX GVWR LBS: 20200 / DSO: 43
146" Wheelbase.
A = Raven Black.
F611= F600 2WD (gas), 20,200 lbs. GVWR
DB8: DB = Black Vinyl (Heavy Duty) / 8 = 81B Custom Cab.
A = New Process 435 4 Speed Manual Transmission.
F33: F3 = Eaton model 15201 Two Speed Rear Axle / 6.33/8.81 / 15,000 lbs. Rear Axle Capacity // 3 = Ford 6,000 lb. Capacity Front Axle.
20,200 lbs. Gross Vehicle Weight Rating.
43 = Milwaukee WI Ford District Sales Office, where the original selling dealer ordered the truck from.
  #77
Old 10-20-2013, 12:28 AM
w6qwa w6qwa is offline
w6qwa is starting off with a positive reputation.
Vin Problem
Trying to buy this truck with vin 1FDTK74N9FVA15254 HELP
  #78
Old 10-21-2013, 03:47 PM
Quote:
Originally Posted by w6qwa View Post
Trying to buy this truck with VIN 1FDTK74N9FVA15254
Welcome to FTE
IFD = FoMoCo USA - Ford Truck - Incomplete Vehicle.
T = Air Brakes ~ Class 3 - 10,000-14,000 lbs. GVWR
K74 = F700 Diesel Conventional Cab.
N = Detroit DDA 990 N or 990T 8.2L (501 cid) V8 diesel.
9 = Check digit, FoMoCo internal use only.
F = 1985.
V = Kentucky Truck Assembly Plant.
A15254 = 1985 Numerical Sequence of Assembly.
  #79
Old 06-01-2014, 12:02 PM
smithgregoryc96 smithgregoryc96 is offline
smithgregoryc96 is starting off with a positive reputation.
vin F70EUD97958
  #80
Old 07-29-2014, 10:43 PM
wcarroll wcarroll is offline
wcarroll is starting off with a positive reputation.
Vin decode help
I need some help decoding a vin on an f 700 it is f70evu11820 any help would be greatly appreciated fairly new to the site
  #81
Old 08-01-2014, 05:23 PM
wolf64 wolf64 is offline
wolf64 is starting off with a positive reputation.
VIN Decode
I need some help with the VIN number from my F 700, could anyone help please?
VIN: F70EVA87796
WB: 176
Color: TT
Type GVW: F702
Body: 416
Trans: 0
Axle: 553
Max. GVW: 22000
D.S.O. : 99
Thanks in advance
  #82
Old 11-30-2014, 01:02 AM
Shade Tree Mech's Avatar
Shade Tree Mech Shade Tree Mech is offline
Shade Tree Mech is starting off with a positive reputation.
Need some hep in decoding a VIN
I just bought a project truck its VIN is N70EVB12528
202 wheelBase
JT color
n702 type/GVW
8A8 body
M trans 55
54M axle
23,000 MGV Lbs
reading through the previous posts and decoding, I think its a 1976 F-700 w/361 2V 5 spd and 2 spd alxe, red out and red in
But what is the N70 mean?
Thanks for all your time and help
stevenh
  #83
Old 11-30-2014, 03:42 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Quote:
202 wheelBase
JT color
n702 type/GVW
8A8 body
M trans 55
54M axle
23,000 MGV Lbs
stevenh
N70 would mean N700. N series
http://www.curbsideclassic.com/wp-co...nseriescab.png
  #84
Old 11-30-2014, 05:12 PM
Thanks for the quick reply, I now have some more questions. I think I will buy the Ford book to have on hand.
  #85
Old 12-05-2014, 03:44 PM
Bubblegum0321 Bubblegum0321 is offline
Bubblegum0321 is starting off with a positive reputation.
New guy question
I tried looking around before asking but it just made me more confused so I'll just tell you my problem. I bought a 75 F100 4x4 last year and have slowly been working on it. The VIN is F10GRV60117. Now from what I have read in this forum is that this truck is a 2 wheel drive (F10), however it is a 4x4. The Dana 44 front axle does not look to have been added but looks original to the truck. I was thinking, could the previous owner have swapped doors, since that is where the VIN plate is? I've looked for the frame VIN but haven't located it yet. Any help would be much appreciated!
  #86
Old 12-06-2014, 09:55 AM
I was thinking, could the previous owner have swapped doors, since that is where the Warranty Plate is located. I've looked for the frame VIN but haven't located it yet.
F10 = F100 2WD
G = 302 2V (excepting 1969/77 Bronco's, 302 not available with 4WD until 1980).
R = San Jose CA Assembly Plant.
V60117 = 1975.
Compare the VIN stamped on the Warranty Plate to the VIN on the registration/title to see if they match.
People replaced damaged left doors with used doors. 99.9% of the time, they failed to install the original Warranty Plates on the replaced doors.
Doors same: 1973/79 F100/350 & 1978/79 Bronco.
  #87
Old 12-06-2014, 10:03 AM
N70 = LN700 (gas) / E = 361 2V or 4V / V = Kentucky Truck Assembly Plant / B12528 = 1976.
W.B. 202
COLOR JT: J = Rangoon Red / T = Candyapple Red
TYPE/GVW: N702 = LN700 (gas), 23,000 lbs. Gross Vehicle Weight Rating.
BODY 8A8:
TRANS: M = Clark model 285V 5 Speed Direct.
AXLE 54M: 54 = Rockwell/Timken Single Speed Rear Axle / 6.83-1 / 17,500 lbs. Rear Axle Capacity // M = Ford 7,000 lbs. capacity front axle with P/S.
GVWR = 23,000 lbs.
It's a 1976 LN700 w/361 2V 5 spd and 2 spd axle
N70 = 1970/89+ LN700 / 1963/69 N700.
This has to be a 1976, as TYPE/GVW was not used on N700's, MODEL code was used instead.
  #88
Old 12-08-2014, 09:52 AM
RedStroke RedStroke is offline
RedStroke is starting off with a positive reputation.
Just upgraded my dump truck. I was told it was a garbage truck and was converted to a dump truck. Any more info is appreciated. Thanks Adam
VIN 1FDNF80C4WVA17033
Type GVW F80260
Body 8
Trans AA
RC 48
  #89
Old 12-08-2014, 05:49 PM
VIN 1FDNF80C4WVA17033 / Type GVW F80260 / Body 8 / Trans AA / RC 48
Since all 500 series and larger trucks were sold as a Cab & Chassis, there's no way to know what type of "back of cab" equipment was installed after it left the assembly line.
IFD = FoMoCo USA - Ford Truck - Incomplete Vehicle (Cab & Chassis).
N = Class 6 Hydraulic Brakes, 19,501-26,000 lbs. Gross Vehicle Weight Rating.
F80 = F800 Diesel Cab & Chassis.
C = Cummins 5.9L (359 cid) 6 Cylinder Diesel.
4 = Check digit, FoMoCo use only.
W = 1998.
A17033 = 1998 Numerical Sequence of Assembly.
Most of the following codes are incomplete and/or were copied down incorrectly.
Type/GVW: F80260 = 60 doesn't belong, should just be F802, but F802 is not listed in the parts catalog.
BODY: 8 = You're missing at least one digit.
AA = Allison model AT-545 Automatic Transmission.
RC 48 = I have no idea what RC refers to, nothing like this is listed in the catalog.
  #90
Old 12-09-2014, 07:46 AM
Thanks for the help Bill. I believe the last 3 digits of the F80260 are the GVW. I saw another 30,000 gvw and its tag said F80300
See tag below.
1981 f700 4x4 cobrajuce Large Truck 20 02-09-2017 07:50 PM
1981 f700 4x4 cobrajuce User Gallery & Picture Display 0 02-05-2017 10:07 PM
F700 vin decode Low Key Large Truck 3 05-15-2016 04:20 PM
Vin decode mikeinmilton Large Truck 18 01-21-2016 07:30 PM
F-700 bronczilla Large Truck 8 03-18-2014 08:37 PM
Tags
1973, 700, 73, check, code, decode, decoder, decoding, f700, ford, number, ranchero, truck, vin, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
