73 F700 vin decode
#61
#62
What is wrong with your 330? You might be better off rebuilding it yourself.
Do you have the HD or the MD version? (larger crank snout on the HD)
Used or reman 330s--googled it:
http://www.nexttruckonline.com/searc...del=All-Models
Overhaul kits:
FORD ENGINE PARTS
Searching is a pita because you mostly come up with late model 5.4 OHC motors, as those are 330 CI as well.
IF you have a MD, medium duty, it might be easier to sub in an FE motor. If you have an HD, you may still be able to sub in a larger FT like the 361 or 391, although those are usually harder to find than the 330.
Overhaul kits:
FORD ENGINE PARTS
#63
Do you have the H/D or the MD version? (larger crank snout on the HD)
Overhaul kits:
FORD ENGINE PARTS
IF you have a MD, medium duty, it might be easier to sub in an FE motor. If you have an H/D, you may still be able to sub in a larger FT like the 361 or 391, although those are usually harder to find than the 330.
Overhaul kits:
FORD ENGINE PARTS
OP has typed three different threads on this topic, at least one has the VIN: F60DVS01693 and as you can see, it's an F600, not an F700.
330 2V H/D uses the same crank as the 361. 330 2V M/D uses the same crank as the 352/360 FE engine.
330 2V H/D uses the same flywheel as the 361 and 391 4V. 330 2V M/D uses a differernt flywheel, it's not the same as any FE engine.
Jack Wolf: FT engines (330 2V M/D - 330 2V H/D - 361 2V [and 1974/78 361 4V] - 391 4V) installed in 1964/78 500 series and larger trucks.
#64
Overhaul kits:
FORD ENGINE PARTS
Overhaul kits:
FORD ENGINE PARTS
#65
1964/78 FT engines: Two different bell housings are listed. One is marked with ID number C4TA-7505-G while the other is marked C4TA-7505-C or -F or -J
Look at your bell housing for its ID number, post what it is, I'll give you its applications.
btw: I'm the only FTE member that has Ford truck parts catalogs for 500 series and larger trucks and I'm 69 today .. so I may be an older phart than you are!
#66
My guess is the difference has something to do with the clutch or mounting, not bolting to the engine.
#68
#70
#71
Did'ja read post 63?
having rough time figuring out how to do things on his site thanks for your help jack Wolf
#74
D = 330 2V Heavy Duty FT engine.
C = Oakville Ontario Canada Truck Assembly Plant.
R630065 = 1973.
For more info, post all the codes stamped on the Warranty Plate, located on the left door face below the latch, or on the inside of the glovebox door.
