73 F700 vin decode - Page 5 - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
73 F700 vin decode
  #61
Old 09-09-2013, 10:50 AM
Jack Wolf Jack Wolf is offline
Jack Wolf is starting off with a positive reputation.
Question F700 330 cu in replacement engine
Sorry not a reply but request can not find where to do this right
1973 330 cu in engine replacement needed internet keeps sending me in circles anyone know where i can get one?
  #62
Old 09-09-2013, 02:50 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
What is wrong with your 330? You might be better off rebuilding it yourself.
Do you have the HD or the MD version? (larger crank snout on the HD)
Used or reman 330s--googled it:
http://www.nexttruckonline.com/searc...del=All-Models
Overhaul kits:
FORD ENGINE PARTS
Searching is a pita because you mostly come up with late model 5.4 OHC motors, as those are 330 CI as well.
IF you have a MD, medium duty, it might be easier to sub in an FE motor. If you have an HD, you may still be able to sub in a larger FT like the 361 or 391, although those are usually harder to find than the 330.
  #63
Old 09-09-2013, 05:11 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Do you have the H/D or the MD version? (larger crank snout on the HD)
Overhaul kits:
FORD ENGINE PARTS
IF you have a MD, medium duty, it might be easier to sub in an FE motor. If you have an H/D, you may still be able to sub in a larger FT like the 361 or 391, although those are usually harder to find than the 330.
Ed, it's a 330 2V H/D FT engine.
OP has typed three different threads on this topic, at least one has the VIN: F60DVS01693 and as you can see, it's an F600, not an F700.
330 2V H/D uses the same crank as the 361. 330 2V M/D uses the same crank as the 352/360 FE engine.
330 2V H/D uses the same flywheel as the 361 and 391 4V. 330 2V M/D uses a differernt flywheel, it's not the same as any FE engine.
Jack Wolf: FT engines (330 2V M/D - 330 2V H/D - 361 2V [and 1974/78 361 4V] - 391 4V) installed in 1964/78 500 series and larger trucks.
  #64
Old 09-09-2013, 05:17 PM
Overhaul kits:
FORD ENGINE PARTS
Thanks do the bell housing of the 361, 391 FT have the same bolt pattern as 330 and can a newer model than a 1973 be used
  #65
Old 09-09-2013, 05:33 PM
Quote:
Did'ja read post 63?
1964/78 FT engines: Two different bell housings are listed. One is marked with ID number C4TA-7505-G while the other is marked C4TA-7505-C or -F or -J
Look at your bell housing for its ID number, post what it is, I'll give you its applications.
btw: I'm the only FTE member that has Ford truck parts catalogs for 500 series and larger trucks and I'm 69 today .. so I may be an older phart than you are!
  #66
Old 09-09-2013, 05:49 PM
They do have the same pattern, but as noted in prior post, two different bells were used. Who knows what the difference was? Might be a deal killer, might not.
My guess is the difference has something to do with the clutch or mounting, not bolting to the engine.
  #67
Old 09-09-2013, 06:01 PM
Bell housing depends on which trans the truck has.
Jack Wolf: TRANS code listed on the 2nd line of the Warranty Plate, located either on the inside of the glove box door or on the left door face below the latch.
  #68
Old 09-09-2013, 06:04 PM
If it's the trans, shouldn't his existing bell bolt up to any FT motor?
  #69
Old 09-09-2013, 06:21 PM
If that were the case, why would Ford list two different bell housings?
  #70
Old 09-09-2013, 11:13 PM
Bell to trans might be different. (like a Clark vs. a NP435 for example) Bell to engine the same. What about clutch differences, hydraulic vs. mechanical? OP needs to look see what he has, but my guess is nothing is going to change from the bell back and any FT HD will bolt up.
  #71
Old 09-10-2013, 12:01 PM
having rough time figuring out how to do things on his site thanks for your help jack Wolf
  #72
Old 09-10-2013, 12:04 PM
Number Dummy you are the Best thanks for your help Jack Wolf
  #73
Old 09-20-2013, 06:53 AM
RedStroke RedStroke is offline
RedStroke is starting off with a positive reputation.
Please decode, just picked this dump truck up for use around the farm..
1973 F600
F61DCR630065
Thanks!
  #74
Old 09-21-2013, 02:06 PM
Quote:
1973 F600 / F61DCR630065
F61 = F600 2WD (gas).
D = 330 2V Heavy Duty FT engine.
C = Oakville Ontario Canada Truck Assembly Plant.
R630065 = 1973.
For more info, post all the codes stamped on the Warranty Plate, located on the left door face below the latch, or on the inside of the glovebox door.
  #75
Old 10-02-2013, 03:52 PM
146 A F611 DB8 A F33
20200 43
1981 f700 4x4 cobrajuce Large Truck 20 02-09-2017 07:50 PM
1981 f700 4x4 cobrajuce User Gallery & Picture Display 0 02-05-2017 10:07 PM
F700 vin decode Low Key Large Truck 3 05-15-2016 04:20 PM
Vin decode mikeinmilton Large Truck 18 01-21-2016 07:30 PM
F-700 bronczilla Large Truck 8 03-18-2014 08:37 PM
Tags
1973, 700, 73, check, code, decode, decoder, decoding, f700, ford, number, ranchero, truck, vin, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
