Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
73 F700 vin decode
Old 08-29-2012, 10:08 AM
Ruffcut2u's Avatar
Ruffcut2u
Ruffcut2u is offline
Thanks Bill for the VIN decode for F70HVGH1993 I have the other numbers from the plate.
GVWR 23100 LB/ 10477 KG
VIN F70HVGH1993
9A, with "Exterior paint color" under it
52, with "DSO" under it
WB.................... 207
Type-GVW........ F701
Body..................AD8
Trans..................CB
Axle..................E3M
with 88494 miles on it.
  #47
Old 08-29-2012, 11:53 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
W.B. 207 / Color: 9A / Type GVW: F701 / Body: AD8 / Trans: CB / Axle: E3M / GVWR: 23100 LB / DSO: 52
Sequence as listed on Warranty Plate:
207" Wheelbase.
9A = White.
F701 = F700, 23,100 lbs. GVWR
AD8: AD = Red all Vinyl / 8 = Standard Cab.
CB = Clark model 282 5 Speed Direct.
E3M: E3 = Eaton model 16244 2 Speed Rear Axle / 7.17/9.97 / 17,500 lb. Rear Axle Capacity // M = Ford 7,000 lb. Capacity Front Axle with P/S.
23,100 lbs. Gross Vehicle Weight Rating.
52 = Dallas TX Ford District Sales Office, where the original selling dealer ordered the truck from.
  #48
Old 08-31-2012, 04:27 AM
karlschloss's Avatar
karlschloss
karlschloss is offline
would you mine decoding my vin as well?
vin
1FDNK74C7PVA33812
  #49
Old 08-31-2012, 04:47 AM
NumberDummy
Originally Posted by karlschloss
Aloha ~ Welcome to FTE
1FD = FoMoCo USA incomplete Ford vehicle.
N = Class 6, 19,501-26,000 lbs. Gross Vehicle Weight Rating range.
K74 = F700 (diesel) Cab & Chassis.
C = Cummins model FD-1060 5.9L (359 cid) I-6 diesel.
7 = Check digit, FoMoCo use only.
P = 1993.
V = Kentucky Truck Assembly Plant.
A33812 = 1993 Numerical Sequence of Assembly, the trucks specific serial number.
  #50
Old 08-31-2012, 01:40 PM
karlschloss
Mahaloz Bill! What does it mean that it was an incomplete Ford vehicle? As you can tell Im new to this forum and have a lot to learn about larger trucks, diesel engines, and how to operate and maintain them. Ive seem to have had a difficult time finding information on the older F700 model and for example on PTOs. When I click on a link at this site theres always tons on threads can I narrow this down w a search for just F700s? FYI I did bid on all three service manuals from ebay and have been browsing those. I would also like to install a hydraulic dump, modify the bed, and treat the entire chassis and bed with zero rust. Thanks in advance for any direction you can give.
  #51
Old 08-31-2012, 02:47 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
Incomplete vehicle = "chassis/cab", or cutaway or certain other configurations where a body or other equipment is to be added by the buyer or another vendor.
For a PTO, post your data plate info to find out what trans you have. Once you know the trans, you can find a PTO to fit. Millions served. The PTO will not be F700 specific, but rather specific to the transmission.
  #52
Old 09-08-2012, 10:47 AM
Kathy Romero Newton's Avatar
Kathy Romero Newton
Kathy Romero Newton is offline
Could you please decode my VIN? F70DUC73119. Thanks.
  #53
Old 09-08-2012, 02:49 PM
NumberDummy
Welcome to FTE
F70 = F700 (gas).
D = 361 2V FT engine.
U = Louisville KY Assembly Plant.
C73119 = 1968, assembled January 1968. This is the F700's specific serial number.
Ford confusion Or, it could be a 1976, as FoMoCo used the same sequence of serial numbers as they did in 1968.
1968 serial number range: C00,001 - D82,000.
1976 serial number range: A00,001 - D25,000.
If a 1976, there's two ways to ID:
The Warranty Plate, located on the left door face below the latch, will have 1976 on the 3rd line between the GVW and the DSO code.
Safety Standard Certification Label intro'd in 1970, glued to the left (drivers) side B pillar below the door striker plate. Has the production date at the upper right or left corner.
  #54
Old 09-14-2012, 10:11 PM
Kathy Romero Newton
It was sold to me as a 1967.
Thank you very much for the information.
  #55
Old 03-03-2013, 08:06 AM
wolf64's Avatar
wolf64
wolf64 is offline
Hi there,
I just bought that F 700 1973 Firetruck. Shes got a Ford V8 with a 4 bbl Holley Carb.
Could anybody help me with the VIN decodeing of that biest.
VIN: F70EVA87796
WB: 176
Color: TT
Type GVW: F702
Body: 416
Trans: 0
Axle: 553
Max. GVW: 22000
D.S.O. : 99
Thank you very much.
  #56
Old 03-06-2013, 04:17 AM
NumberDummy
Originally Posted by wolf64
I just bought a F700 1973 Firetruck. Shes got a Ford V8 with a 4 bbl Holley Carb.
VIN: F70EVA87796 / WB: 176 / Color: TT / Type GVW: F702 / Body: 416 Trans: 0 / Axle: 553 / Max. GVW: 22000 / DSO: 99
F70 = F700.
E = 361 2V or 4V FT engine.
A87796 = 1976 (1976 serial number range: A10,001-D25,000) / (1973 serial number range: Q00,001-S60,000).
176" Wheelbase.
Will finish this decode later today, microfiche bulb just burned out.
  #57
Old 03-12-2013, 11:18 AM
wolf64's Avatar
wolf64
wolf64 is offline
F 700 Decode
Thank you for this information so far.
Please, could you decode the rest of the VIN also, if your microfiche reader is working again.
Thanks and have a nice day.
  #58
Old 04-05-2013, 12:51 PM
Lovelady farm's Avatar
Lovelady farm
Lovelady farm is offline
F700 decode please
Buying a f700 4x4 and need vin decoded please help thanks
F66evv80386
  #59
Old 09-01-2013, 04:29 PM
DK Farms's Avatar
DK Farms
DK Farms is offline
Bill, you da man!! Thanks for helping us with this decoding stuff. I have another one for you. I bought a '79 F7000 diesel grain truck with a dump bed. The data plate on the door is obviously incorrect since the VIN starts with F10. The plate is painted over and the door handle is different so apparently the door was replaced and the plate wasn't transferred. From the registration, the VIN is K70BVFC9184. Is the plate data replicated anywhere else on the chassis? Thanks for any decoding help you can offer.
  #60
Old 09-01-2013, 09:21 PM
NumberDummy
K70 = F700 Diesel.
B = Caterpillar V190-3208 636 cid V8 Diesel or Cummins KTA 600 1150 cid I-6 Diesel.
FC9184 = 1979.
There will be a hidden VIN stamped on the top of the frame rail, but where it is on your truck, I dunno.
You can get a duplicate Warranty Plate with all the correct codes stamped on it by passing along your VIN to martiauto.com
Quick Reply: 73 F700 vin decode
